Baileynet valve
   / Baileynet valve #2
FYI-You linked a 2-spool...
There are equivalent valves at the Surplus Center also...
What are you using it for? And what is the GPM specs for your machine?
Edit to answer this:
I am assuming that Tandem Center means the same as Open Center. Am I right?
Read THIS thread.
   / Baileynet valve
I am using it for rear remotes on a FarmTrac 270DTC. I only have about 7-8GPM so it should work fine. I would be operating a TnT and use the third for things like my post driver. The picture in the earlier link I think is just a generic picture. If you look at the No. it is 3 spools. I think their descriptions are confusing.
   / Baileynet valve #4
You are right Eric, I did not read close enough...
$158 for a 3-spooler is a very good price-go for it.
   / Baileynet valve #5
I recently put the 3 spool and 2 spool version of these in 21 gpm in a plow/dump truck. Very good quality and very happy with them. If you are using anything for power beyond, I would spend a little more for the higher gpm. Just me though.
   / Baileynet valve #6
Do they have PB ports on them? I would like to get a 3 spool version if they do.
jb
   / Baileynet valve
I just checked the tractor specs again. The pump only has 6.2 gpm capacity. Do you really think it would make any difference going from a 10 gpm valve to a 21 gpm valve? In terms of PB the 3PH will be after the valve. I can plumb the loader either before or after. My first intent was going to be after the loader valve.
John: I sent a message to them about PB on this valve. I will let you know what I hear. I did download their catalog and in it they say the valve comes with PB.
   / Baileynet valve #8
I don't think you gain anything by going to the larger capacity valve. In fact, it may be "twitchy" to operate as it won't have the low flow fine control that the smaller valve will have.
I didn't see the link to DL the catalog. Have to look again. And THANKS in advance for letting me know about the PB port! That price on a 3 spool is sweet.
jb
   / Baileynet valve #9
Found the catalog. Yep, it says they have PB. Looks like the wallet may get cracked open.
jb
   / Baileynet valve #10
In that case, you're fine with the 10 gpm.
you need part # 220-915, power beyond plug, it's $16 and at the bottom of the page.
2017 Ford Transit Connect Passenger Van (A55788)
2017 Ford Transit...
Vermeer 840 Discbine (A50775)
Vermeer 840...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2011 Toyota Corolla (A55758)
2011 Toyota...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
