4410 Not Moving
   / 4410 Not Moving #1
KevinLSt36
I bought a 2004 4410 about a year ago. It started giving me issues a couple of weeks ago. Basically Skipped while i was running a roto-Tiller and stopped moving, tilling, everything. Its an eHydro with MWFD. I tried to check the Hydro fluid level but the gauge was foggy so i just drained all the fluid out from the bottom (screen filter). Ive replaced the screen Filter and both other filters. They gave me a rockshaft control valve filter as well but i dont seem to have one on the tractor. The Fluid was Extremely Dirty (yellow and gooey).....
After doing this I filled it back up with new Low Viscosity HyGard (i put in a full 28 Quarts. It says its capacity is 27 quarts but it was still showing low in the gauge. It started running and driving. PTO working, everything. For about 10 minutes. Its back where it started now, Nothing moving. I can feel the pump start every now and then and start to raise the bucket like it was doing before. What Next???? It has been giving me a code (short Long Long Short)
   / 4410 Not Moving #2
Hopefully, others with more experience than me will chime in. However, I will offer a thought.
You may not have gotten rid of all the bad fluid and/or goo that was plugging things up before. Therefore, your screens and filters may be plugged up once more. I think there was another thread on here where the guy had a similar problem.
I'm wondering what is the best way to flush this out. Perhaps someone can suggest how this should be done.
   / 4410 Not Moving #3
Two things come to mind:
1) You sill have contaminated fluid like Dennis mentioned and the screen is plugged up again.
2) The pedals are out of calibration. You need to identify the code.
   / 4410 Not Moving #4
Any chance you bumped the switch by the turn signal? Or one of the other switches, its computor controlled and you must go by the operators manual. Play with it and turn on and off some switches and you find you go nowhere.----Fuseboxer
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
