oldmech
Gold Member
- Joined
- Dec 26, 2006
- Messages
- 468
- Location
- Quebec
- Tractor
- Two Gravely Two L One with 10 h.p Dek-Diesel engine one Grillo 107d and one BCS 735 diesel
I choose a L model with reduction gears . For GOOD SPEED as L8 in low range (May be a little bit sloower) For GOOD BALANCE. I am very happy with this new tractor. The REDUCTION GEARS is A MUST For my adapter. Pic no. 1 How first step: We need crankcase and the input- Sun-gear shaft from the Gravely crankshaft. We must adapt a CL-100 x 11\16 Flex joint for fit on the taper input shaft-sun-Gear. a 86$ machine shop work for me. Pic no. 2 I add two oil galeries on half trans crankcase Pic no 3. Next step later. If you have questions Good Luck! Oldmech
