Bl8tant
I'm working on a friends Gravely 14-G Rider. I rebuilt the motor with no problems. The next step is the transmission. I'm hoping someone with experience with these can give me some suggestions before I open her up. The service manual is rather skimpy in the troubleshooting section.
The problem:
You can shift freely between 2nd and 4th. However, if you move the lever to neutral and use 1st or 3rd, it is nearly impossible to get it back over to use 2nd and 4th. It takes lots of rocking the tractor, and fidgeting with the lever.
Anyone ever have this issue? What turned out to be the problem?
Also, once fixed what would this machine be worth. It has been well cared for and has a fresh motor (0 hours).
Thanks.
The problem:
Thanks.
