Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1
    Member
    Join Date
    Mar 2009
    Posts
    35
    NC
    BCS 853
    Default Mowing 2 acres
    I have read about the different types of mowers but I am looking to cut a large flat area. If the grass lays over, the sickle bar won't cut it. The BCS finishing mower is 38". The other mowers are even narrower. Currently, I am paying someone else to mow it.
    I noticed the other day that although he has a 3 pt hitch, he is not actually lifting the mower, other than loading it onto his trailer. Since his finishing mower is not being supported by the tractor, I would think that the 853 could drag it around the field. I certainly could use the exercise.
    The field needs to be cut to control the field mice population. Although they remain in the field during the summer, they relocate during the winter and the wife does not appreciate their company.
    853 w/Lombardini engine, Rotary Plow, 30" Tiller, 38” Lawn Mower, Root Digger, & Ridger
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Gold Member farmerboybill's Avatar
    Join Date
    Mar 2008
    Posts
    460
    Southwestern Wisconsin
    BCS 850 diesel and 735 diesel
    Default Re: Mowing 2 acres
    Hey,
    You're looking to get a finish mower bigger'n the 38 inch mower? How big? I think your best bet to to talk to Joel about something that would mount up directly or talk to Oldmech about making you a gravely adapter. Here's a 50 inch Gravely deck for a walk-behind on eBay - gravely walkbehind 50" deck - eBay (item 150335731475 end time Apr-05-09 15:21:28 PDT) I don't know how much bigger they made 'em, but I doubt you want to go much bigger'n this one..
    I have the 38 inch mower for my BCS 850. I used it a little bit on a 715 last year, but haven't had an opportunity to use it yet this year on the 850. I think it'll do everything i want to do with it. Of course, I'm only doing a half acre lot with a house on it.
    BCS 850 w/ Kohler Diesel, 30" tiller, 18 inch combined ridger, 36" dozer blade, 28" snow thrower, BCS BIO100 chipper, blade, 38" mower, 26 inch rough cut mower, 36 inch sickle, trencher, 2 way plow, ridger, hiller/furrower
    Deere 60, 3010, 3020, 4010, 4020, 4430, 4640, 4840 and all the implements to work 'em
  4. #3
    Member
    Join Date
    Mar 2009
    Posts
    35
    NC
    BCS 853
    farmerboybill
    Belated Congratulations. Watch out, they grow up fast!
    I missed the mower deck posting.
    I'll send OldMech a message and ask him to offer an opinion. With my diesel engine, I would think that spinning the blades would not be a problem. Stabilizing the deck might be another story. And safety is another question. Would hate to kick a rock or try tossing a blade with me at ground level.
    How much of a bank angle can you cut with the 38" mower? I have 500' of ditch bank along the state road. (Close to 1,000' if you count down and back.) Right now, I pay someone to weedwack, because it is too steep and wet for a riding mower. (We get plenty of rain, with an already high water table.)
    Also, do you know the width between the wheels on your 850?
  5. #4
    Join Date
    Mar 2008
    Posts
    460
    Hey,
    My biggest concern is the fact that it doesn't pivot at the connection like the sickle mowers and brush mowers. With the rigid connection, I don't know how it would do going over rough or sloped terrain. I've been meaning to talk to Joel about it, but haven't. Perhaps there's an adapter that would give me 15 degrees of flex like the other mowers.
    The wheel width is whatever you wanna make it. Right now, mine are 26 inches center to center (32 at the widest), but I have the 5 total inch fixed axle extensions, some custom made 9 inch total extensions, and trailer rims instead of the stock offset rims. I think the total width standard is 22 inches for my machine with stock offset rims. Your 853 should be the same.
    I posted some pics of my custom made adapters. They're sized to fit the BCS hub on the inside and trailer rims on the outside. I welded the round stock for free weights right on the extensions, allowing me to use the other ones on my 730.
    Attached Thumbnails Attached Thumbnails Mowing 2 acres-04-03-09_1616.jpg   Mowing 2 acres-04-03-09_1617.jpg
  6. #5
    Gold Member
    Join Date
    Dec 2006
    Posts
    396
    Quebec
    Two Gravely Two L One with 10 h.p Dek-Diesel engine one Grillo 107d and one BCS 735 diesel
    Hi! Voyageur! Two acres 80k sq ft. I cut grass on my neighboor land 32K ft (About 3-4 hr) two times by year I use my 30 in. Gravely rotary mower because Grass is very high( more 12 in.) and very deep. My 10 hp diesel work very hard in first gear with the 30 in. At home I use (weekly) my homemade 42 in. two blades finnish mower in second gear. You know More large = more power or less speed always power is the limit . May be you can use a 31 in. BCS brush mower in two or third speed for 10-12 hrs total. Personnal I like walk behind for 1-2 hours for more I take my one wheel sulky. I dont think a more large mower can make more large area. The brush mower can be use for grass or brush etc. I use mine for clean my garden in fall . I mow 6 Ft corn (impressive) beans etc.. Powerfull implement. The finnish mower make a better job for grass. The best is two but I will take the Brush first. Good luck ! Oldmech
  7. #6
    Member
    Join Date
    Mar 2009
    Posts
    35
    NC
    BCS 853
    I forgot that the bigger the deck, the slower I would have to go. Maybe the 38" BCS Finishing Mower is what I should look at. I will figure out the angle of my ditch bank this weekend. I could justify the 38" BCS if I can mow the bank safely.
    If I do a good job on the garden, maybe my wife will let me buy the bush hog in the fall!
    Mark
  8. #7
    Gold Member
    Join Date
    Dec 2006
    Posts
    396
    Quebec
    Hi! For your bank. Can you walk on EASY Are you confortable. For incline or angle Small engine can go to 20 -25 degre . More are risky for oil lubrication. Some years ago I work on camping ground near a river. Very dangerous if too incline ! If too wet. I remember. Good luck Oldmech
  9. #8
    Member
    Join Date
    Mar 2009
    Posts
    35
    NC
    BCS 853
    That is something to remember. With the mower in front of me, I would be less likely to get into the blades.
    As for the angle, I will measure the bank this weekend and then call Joel.
    There is about 150' of steep bank. Then a drain tile and from there it is significantly less.
  10. #9
    Join Date
    Jan 2008
    Posts
    578
    SE Ohio & SE Florida
    Quote Originally Posted by farmerboybill View Post
    Hey,
    The largest Gravely offically sold for a 2-wheeler was a 60" 3 blade deck. But if you had the guts to operate one, you could get a 72" and change the gearbox over to the same as a 40/50/60 inch deck. The 2-wheeler would need steering brakes and duals plus you'd need the kind of rare 16 HP models.
  11. #10
    Member
    Join Date
    Mar 2009
    Posts
    35
    NC
    BCS 853
    What would it take to connect a Gravely deck to a BCS?
    This is making me ask again as to whether you could connect a 60" deck made for a standard tractor. As I stated in my original post, they are only lifting them to load and unload. Otherwise they are supported by the four wheels.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
