09-05-2009, 08:28 PM
#1 (permalink)
| | Bronze Member
| Digging potatoes with a BCS 730 and root digger Hey all,
I just posted a video of me digging potatoes with my trusty rusty BCS 730 on Youtube.com. You can read my long-winded description of the machine and how it did on the video description.
The first pic shows the potatoes that weren't reburied, the second shows all of them from one row. The third pic shows the machine from the drivers seat. The fourth shows a view from the side. Big tires for a 730, eh? YouTube - BCS 730 with 8 HP Kohler Magnum pulling a Mainline potato plow
Bill in WI
__________________ BCS 850 w/ 14 horse V twin Briggs and BCS 730 w/ Kohler Magnum 8 and 30 inch tiller, 26" tiller, 18 inch tiller, 18 inch combined ridger, 36" dozer blade, 28" snow thrower, BCS BIO100 chipper, blade, 38" mower, 26 inch rough cut mower, 36 inch sickle, trencher, 2 way plow, ridger, hiller/furrower Deere 60, 3010, 3020, 4010, 4020, 4430, 4640, 4840 and all the implements to work 'em |
09-05-2009, 11:43 PM
#2 (permalink)
| | Bronze Member
| Re: Digging potatoes with a BCS 730 and root digger looks great! |
09-06-2009, 12:46 AM
#3 (permalink)
| | Veteran Member
| Re: Digging potatoes with a BCS 730 and root digger Nice Spuds.
__________________ Jason
ambitious but rubbish |
09-07-2009, 02:51 AM
#4 (permalink)
| | Gold Member
| Re: Digging potatoes with a BCS 730 and root digger Aaahh Beauty !!! Machine,..AND..Spuds,.....very nice indeed!!
CHEERS!
. . tug |
09-07-2009, 02:33 PM
#5 (permalink)
| | Silver Member
| Re: Digging potatoes with a BCS 730 and root digger Taters! Get your fresh taters! Looking good.  |
09-08-2009, 02:26 AM
#6 (permalink)
| | New Member
| Re: Digging potatoes with a BCS 730 and root digger Now you've got me searching Craigslist daily for an upgrade to our 715, since it will barely pull the hiller/furrower. |
09-08-2009, 11:57 AM
#7 (permalink)
| | Silver Member
| Re: Digging potatoes with a BCS 730 and root digger Hi! Farmerboybill I am curious. What the tires and wheels size. Congratulation ! Your potatoes look very good. Here we had too much rain this year. Good luck! Oldmech |
09-08-2009, 11:17 PM
#8 (permalink)
| | Bronze Member
| Re: Digging potatoes with a BCS 730 and root digger Thanks to all the well-wishers! I'm hoping to make more videos of my BCS stuff since there seems to be few relating to them.
Hey Oldmech,
They are 6-12 tires mounted on 4 bolt trailer rims. I had a local welding shop make the adapter/extensions. The trailer rim's bolt pattern is just a skosh too big to mount directly to BCS machines. Since I was having them made up, I also had the 1 inch round stock welded on to hang weight. I can put about 100 lbs per side. Sure enough, i found a pair of 5-12 tires almost immediately after I had 'em made up. How's the 735 Diesel been treating you?
Hey Clytle,
I'll bet your 715 has every bit as much oomph as my 730. They're essentially the same machine. My 730 has an 8 Horse Kohler Magnum, the same as the 715 I used to have. The only thing better about the 730 is instant reverse and an actual shift pattern. You just need bigger tires and weight at the wheels.
Bill in WI
09-09-2009, 08:06 AM
#9 (permalink)
| | Silver Member
| Re: Digging potatoes with a BCS 730 and root digger Hi ! The 735 is my work horse. The ACME diesel is a fine engine take less one liter hour. At first in spring often the engine was stopped after 15 min. I change fuel filter ( I think this one was never changed because the blue paint on)Now no more trouble . Also I fit the Mainline mower with home made adapter All run very good. Thanks you again and Good Luck! Oldmech |
09-09-2009, 08:00 PM
#10 (permalink)
| | New Member
| Re: Digging potatoes with a BCS 730 and root digger The 715 would proably do it okay with the bigger tires and lots of weight. Ours is used in hilly areas an I'm afraid I wouldn't turn it after adding the weight and tires, or would loose control with the free wheel devices.
I need faster speeds in front PTO mode, easier reversing, and individual brakes on the hills.
Cory |
