Hey Mark,
You could possibly unstick a clutch by putting the machine in gear, starting the engine, and working it with the clutch handle squeezed until the clutch lets loose on its own. One guy told me he used to unstick them by running the machine into a brick wall with the clutch disengaged. Perhaps that's why I had 2 715s with the guards broken off them. Your mileage may vary.
Cone clutches have an Allen head screw on the side of the clutch instead of down the center of it. You line up the screw with a notch that has been cut out of the adapter and take it loose there.
I don't think a c-clamp will be sufficient, but maybe. The last clutch I unstuck required a significant amount of force from a 5 inch vise. If yours is only slightly stuck, maybe a c-clamp will do it. If you have a shop press, that will work, too
Bill
