Page 7 of 13 FirstFirst ... 45678910 ... LastLast
Results 61 to 70 of 129
  1. #61
    New Member
    Join Date
    Dec 2010
    Posts
    13
    Default Re: "Powersafe" clutch on BCS
    Something to consider is that yes the 853 and 740 are similar machines, however for what ever reason BCS Italy has chosen to block off the 4th gear and there must be a reason for that. So I highly recommend anyone from modifying their 740 in the manner above.
    Having said that, I did compare an 853 with a 740 and found that both have the welded tab on the steering column base that prohibits the ability to shift the 853 into 4th gear with a front-mount attachment. It appears that one can, indeed, achieve the transport speed for rear-mount attachments in the 740 by changing two parts -- install the 853 gear shift quadrant (p/n 561.57239) and the 853 "joint" (552.47644). The joint has the elongated lobe that contacts the welded tab; thereby preventing the gear shift from going into 4th gear with front-mount attachments. Please note the joint should be ALWAYS used when doing this, that way it will lock out the high speed gear, so it doesn't run you over when accidently shifted into reverse!.. Think safety!!!!!!!!
  2. #62
    Platinum Member farmerboybill's Avatar
    Join Date
    Mar 2008
    Posts
    783
    Southwestern Wisconsin
    BCS 850 diesel and 735 diesel
    Skyborne,
    Someone on here (Oldmech?) said they blocked it off for the new EU standards. On top of the rules that spawned the Powersafe (forward motion and power attachment needs to stop within a second and leave the engine running) the EU decided these machines were too dangerous over 10Km/H. Since 4th gear is 13.28 km/h, it had to be blocked. Frankly, with the violent stop that comes with stopping the wheels within one second, I am compelled to agree with them. What I don't understand is that they could have changed the gearing in the transmission to make 4th exactly 10km/h instead of eliminating it completely. After all, they recast the transmission housing to fit that Powersafe. I can't believe changing a sprocket or two in the new housing would have added much more expense
    All Grillo walk-behinds have had the transport gear blocked as well, but it's a simple matter of taking out a small bolt with three washers to regain transport. They never changed their transmission to comply with EU standards, but slightly changed the clutch and OPC to meet compliance. They are ordered by Joel without these changes so the machine that was sold in the US last year is the same machine this year - except for that bolt blocking out transport...
    BCS 850 w/ Kohler Diesel, BCS 735 w/ Acme diesel, Agrizeta tracks, 30" tiller, Berta double rotary plow, Berta 33" 2 stage snow blower, 18 inch combined ridger, Caravaggi BIO90 chipper, Bellon 32"rough cut mower, Caravaggi stump grinder, BCS 59" duplex mower, Pallidino 20" flail mower, Ravenna trailer, trencher, 2 way plow, ridger,
    John Deere B, 60, 4430 open station, 4430 SGB, 4840, 317 skid steer, and all the implements to work 'em
  3. #63
    Gold Member
    Join Date
    Dec 2006
    Posts
    468
    Quebec
    Two Gravely Two L One with 10 h.p Dek-Diesel engine one Grillo 107d and one BCS 735 diesel
    Hi! I remimber I read the new EU rules . The maximum speed for two wheels tractors is 8 kmh or 5 mph. I think in near futur company as BCS or Grillo remove the 4th gear. Good luck Oldmech
  4. #64
    Join Date
    May 2006
    Posts
    124
    We got and 852 that was brought from Canada since all the 853s were backordered. What I understood from Joel was that the final drive is a worm gear and the only difference between the 2(852 853) is one worm is left hand and the other right hand. The reason it will not reverse is because the 4th gear skips most of the transmission and locks the worm to the input shaft.
    So BCS would have to remake the worm and its driven to lower the max speed, and that would lower all the other gears also.
    Cory
  5. #65
    Join Date
    Apr 2012
    Posts
    75
    Germany
    BCS 740
    Hi
    Thank you for all your input!
    As I only know the new PowerSafe clutch, I can't comment on the clutch issue.
    Like most of you, I'm also surprised and sad to see the 4th gear disappear. As mentioned above, the 4th gear hasn't disappeared all together, it has just been blocked.
    I am not a lawyer, but I read the directive 2006/42/EC this weekend. This paper has been in effect in the European Union since December 29th 2009, and my guess is, that the 4th gear has also been blocked to comply with this paper. In article 3.3.4 "Movement of pedestrian-controlled machinery" is stated, that "The speed of travel of the machinery must be compatible with the pace of a driver on foot." Sadly most of us can't walk at a pace of 8.35 mph
    Like some of you mention, walking behind the tractor in 4th gear at idle (3.25 mph) also makes more sense to me, than walking at full throttle in 3th gear (2.68 mph). But that's politics for you I guess!
    Best regards
    Jens
  6. #66
    Join Date
    Apr 2012
    Posts
    75
    Germany
    BCS 740
    Hi again
    I fully agree, that when working with a potentially dangerous 2-wheel tractor, for sure safety shall be our top priority. I feel confident though, that the members of this great forum are all fully aware of that.
    The loss of the transport gear on the new BCS models seems to a frequent topic in this forum, so I decided to take my little test to the next level. As you can see on the pictures below, it all worked out fine
    On my BCS 740 I changed the gear quadrant and the joint to a BCS 853-type (p/n 561.57239 and p/n 552. 47644). As long as BCS does not remove the worm transport gear all together but just blocks it, this gives you the 4th transport gear almost for free.
    In order not to compromise safety, I also highly recommend you to change the joint to a BCS 853-type, if you change the quadrant! As seen on my photos, this will prevent you from accidentally selecting the transport gear when in the front-PTO (mowing) mode (left picture), as the joint and the welded tap seen on the far left, only allows the 4th gear to be selected when in the rear-PTO (tiller) mode (right picture), and will block it when in the front-PTO mode.
    In order to secure the joint to the gear lever, you will also need the pin (p/n 342.13022). As the gear quadrant comes without any placards, you might also want the decal (p/n 580.57704) too, in order to find the proper gear.
    Please do not forget, that because the worm transport gear bypasses the normal gearbox, it will always drive backwards when in the front-PTO mode, disregarding the position of the reverse lever!!!
    "Powersafe" clutch on BCS-dsc02923-jpg"Powersafe" clutch on BCS-dsc02925-jpg
    Best regards
    Jens
  7. #67
    Join Date
    Mar 2008
    Posts
    783
    Hey Jens,
    Thanks for checking this out. It's good information to have. Now, WHY didn't BCS America order the "new" 749 with these changes for the US market???
  8. #68
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,994
    Waynesboro Va
    John Deere X310, JD LA 145
    I don't know much about BCS tractors but have wanted one for my garden. I read somewhere on line that a BCS dealer had ordered 2 machines with the new clutch and one did not work and needed major repairs from the start. He said he would not sell his customers a machine that had a 50% break down history in his shop. Any one else heard this?
  9. #69
    Join Date
    Feb 2005
    Posts
    591
    Default
    Quote Originally Posted by Ed of all trades View Post
    That was said on this forum. It is my take there are bugs to work out, but I doubt its that bad.
  10. #70
    Join Date
    Feb 2012
    Posts
    116
    Hector NY
    BCS 605, 740, 850
    I heard that there have been 2 clutch failures reported. One I know nothing about but one was run without the dipstick in place when they were chipping wood with the chipper/shredder. Wood chips got in the hydraulic oil which caused the pump to seize. These are repairable clutches for which BCS has issued a full repair overhaul manual. The clutch comes with a 5-year warranty verses the 3 year warranty on the standard spring clutch. The dealer that reported the "50% failure rate" must have changed his mind as I have had calls from his customers requesting operating details and the spec for the hydraulic oil in the transmission. Too bad he didn't buy from a local dealer who would have gone over the operating controls and gotten the oil spec.
    BCS has been selling their tractors with this same clutch for 3 years now. If they had a 50% failure rate they would not be still offering this product. I personally sold three units with the PowerSafe clutch system with no problems including on the 749 diesel powered unit.
Similar Threads
  1. Clutch Life Expecancy in Hours
    By mrlullabye in forum Owning/Operating
    Last Post: 06-22-2013, 05:25 PM
  2. BCS 720 YEAR 2000 MODEL CLUTCH HELP
    By antoniod in forum 2-Wheeled Tractors
    Last Post: 09-20-2010, 10:33 AM
  3. BCS 715 Tractor Clutch
    By hwm in forum Parts/Repairs
    Last Post: 09-14-2009, 10:31 AM
  4. Dual Stage Clutch JD 1050
    By jgbanshee in forum John Deere Owning/Operating
    Last Post: 04-26-2008, 11:12 PM
  5. Why use clutch with GST?
    By Jay4200 in forum Kubota Owning/Operating
    Last Post: 10-09-2006, 01:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
