Results 1 to 8 of 8
07-19-2012, 06:51 PM #1New Member
- Join Date
- Jul 2012
- Posts
- 3
- Location
- Vesloes, Denmark
- Tractor
- BCS 737 (ACME)
Renovating a BCS 737
Hi
I am a (very) happy owner of an old 737. Bought it with a large three rotor mower last summer for 3500 kr (about 600$) but havent had time to mess arround with it untill now. It is in quite poor condition and looks like it has been spending alot of time in rainy weather.
But is starts immediately. It kan shift gears and the PTO is spinning. The ACME engine sounds fine and runs steadily even in idle running. Some cleaning, rust removal and paint has now made it look very fine again.
I just bought a sickle bar (Ferrari) and is about to start using it for hay making for our Boer goats.
Questions:
1. The engine is old, so do I have to use leaded gasoline?
2. Acording to a manual I found on the net, the transmission holds 2 litres of oil, but I only drained about 1 litre fom it. I have filled 1 litre on it again and it now reaches the upper marking on the dip stick. What is the correct amount of transmission oil. One or two litre?
Best regards
Ejnar Dahl Jensen (Gl. Vesløs, Denmark)Last edited by ejnardahl; 07-20-2012 at 06:46 AM. Reason: bad spelling
07-20-2012, 11:41 AM #2Gold Member
- Join Date
- Mar 2008
- Posts
- 453
- Location
- Southwestern Wisconsin
- Tractor
- BCS 850 diesel and 735 diesel
Re: Renovating a BCS 737
Nice looking machine you have there.
1. No. The 737 was built in the early 90's, so it' not exactly ancient. No lead needed.
2. If you drained it as it sits in your pic, you didn't drain all of it. You need to have it tilted back to get all the oil out.BCS 850 w/ Kohler Diesel, 30" tiller, 18 inch combined ridger, 36" dozer blade, 28" snow thrower, BCS BIO100 chipper, blade, 38" mower, 26 inch rough cut mower, 36 inch sickle, trencher, 2 way plow, ridger, hiller/furrower
Deere 60, 3010, 3020, 4010, 4020, 4430, 4640, 4840 and all the implements to work 'em
07-21-2012, 03:40 PM #3New Member
- Join Date
- Jul 2012
- Posts
- 3
- Location
- Vesloes, Denmark
- Tractor
- BCS 737 (ACME)
Re: Restoring an BCS 737
Thank you for the reply. the oil was not drained in this position. I tilted it both forward and backward to make sure that as much as possible of the old oil was out.
Have used quite a bit today... and this is really an awsome machine. Only wish it could drive a bit faster than third gear. When driving to and from the garage it fells a bit slow :-).
07-22-2012, 11:11 AM #4Bronze Member
- Join Date
- Feb 2009
- Posts
- 52
I just finished a 725 to 735 conversion on my tractor and it took just a little over one liter to fill to the upper mark also. I left it and have checked it several times - still looks ok to me. I believe that these are like most other transmissions and your better off not overfilling.
07-22-2012, 09:27 PM #5Silver Member
- Join Date
- Mar 2008
- Posts
- 167
Put larger diameter wheels and tires on the tractor to increase the ground speed. Look at the information on this page: Tractor Accessories
07-22-2012, 09:40 PM #6Banned
- Join Date
- Dec 2011
- Posts
- 1,129
- Tractor
- L5450
On my 722 I can barely walk fast enough in 3rd to keep up with it. I assume you have 4 gears? Do you need to have the engine in front to be in high gear? I would assume the engine towards you is considered reverse to the machine?
07-23-2012, 07:19 PM #7New Member
- Join Date
- Jul 2012
- Posts
- 3
- Location
- Vesloes, Denmark
- Tractor
- BCS 737 (ACME)
No the fourth gear is blocked when reserved, but this is not a major problem.
I am now on the lookout for a hay rake, but they appear to be very rare in my country. I am considering to get an adapter that will allow me to use a tractor sized PTO and that way get acces to a all the used hay rakes for normal tractors. But I am a little nervous that my little 737 may not be able to handle it. And that the PTO gearing may be a problem. Any experiences?
07-23-2012, 08:35 PM #8Gold Member
- Join Date
- Mar 2008
- Posts
- 453
- Location
- Tractor
The fourth gear is only accessible in "tractor" mode. You'll need to find the sister model - a 605 - to get fouth in "mower" mode.
I think you'll have several problems with pulling a 4 wheel tractor-type rake. First, the tractor style ones have the PTO above the drawbar and you'll have the PTO below. Second, the PTO turns at 990 RPM on a BCS. The 6 spline PTO on a full sized rake will be 540 RPM. I have not tried to use one, but you should be able to find a ground driven bar rake in Denmark. I don't think you'll have enough traction w/o overloading the little BCS, but maybe...
BTW, I spent a little time on the island Romo when I did a foreign exchange program. I lived in the village of Emmelsbull Deutschland for a summer. Gotta say, I didn't see anything other than beautiful women in Denmark.BCS 850 w/ Kohler Diesel, 30" tiller, 18 inch combined ridger, 36" dozer blade, 28" snow thrower, BCS BIO100 chipper, blade, 38" mower, 26 inch rough cut mower, 36 inch sickle, trencher, 2 way plow, ridger, hiller/furrower
Similar Threads
BCS 737 price....
By next61 in forum 2-Wheeled TractorsReplies: 4Last Post: 02-03-2012, 12:37 AM -
BCS 737 tiller to snow blower conversion
By unnet in forum 2-Wheeled TractorsReplies: 3Last Post: 11-13-2011, 09:38 PM -
BCS 737
By henerythe8th in forum Private Party Ads ArchiveReplies: 1Last Post: 03-08-2010, 02:23 PM -
a new to me BCS 737
By farmallmann in forum 2-Wheeled TractorsReplies: 8Last Post: 10-12-2009, 08:26 PM -
Snow Attachments BCS snow blower and BCS lawnmower performance??
By MikeB2005 in forum Snow RemovalReplies: 17Last Post: 02-28-2005, 01:06 PM
