Results 1 to 9 of 9
  1. #1
    Bronze Member jd4310man's Avatar
    Join Date
    Mar 2006
    Posts
    57
    Scottdale, PA
    John Deere 3203
    Default Got a 605 BCS With 5 attachments
    Found a BCS 605 last week on Craigslist for $1500 with 5 attachments. It came with a 12hp Acme gas engine. I got a 26" tiller, 28" snow blower, 40" sweeper, and a 40" side discharge rotary mower. I even got an extra set of turf tires, quick coupler kit, and various other parts. I have a 1978 BCS 715 that has an Acme 8hp diesel that I am switching over to the 605. I have to upgrade the cone clutch to a heavy duty one as i cant exchange clutches with the 12 hp gas because of engine shaft differences. The gas has a tapered shaft that is tapped for a Alan head bolt wile the diesel has the same taper, but is threaded on the end. I spoke with Joel at earth tools and he can get me the right fitting clutch for around $250. This is an early model 605 that has a hybrid pto coupling. It uses the old spline shaft type coupling but also used the first stile flat three dog coupling that was only produced for a few years. I found this out because all the attachments except for the 40" mower use the spline shafts. the mower was upgraded to the flat 3 dog type. I had to fix the snow blower as the metal was cracked where the gearbox input shaft meets the main body of the blower. I added a metal brace to help prevent further cracking. I plan on repainting everything as after 20 years take there toll, parts are looking weathered. The 40"mower will need some attention as well to get it ready for spring. I will post more pictures of the whole rig when I get a chance. I cant thank Joel at earth tools enough on helping me get this thing up and running as he has the answer to any problem, as well as the parts on hand to fix it too. (This is the pic that was posted on Craigslist) Got a 605 BCS With 5 attachments-3mb3f23h25nf5l15kbd1rfc9fbf16496d1a36.jpg
  2. #2
    Elite Member milkman's Avatar
    Join Date
    Sep 2001
    Posts
    3,042
    Ky
    BX2200, BCS 735
    Default Re: Got a 605 BCS With 5 attachments
    Good looking machine, I have the same mower that I got with my 735, back in '87. I've never run it with the cover off the belt, and mine is the original silver color. Did you get the sulky to go with the mower? That was a decent price for all that stuff.
    Hate is like drinking poison, hoping your enemy will die. unknown author
  3. #3
    Super Star Member
    Join Date
    Jul 2011
    Posts
    10,446
    Yanceyville, North Carolina
    Kubota L4400
    Congratulations.
    The PUPIL who does not surpass his Master, fails his Master.
  4. #4
    Join Date
    Mar 2006
    Posts
    57
    Scottdale, PA
    John Deere 3203
    No, there wasn't a sulky. I have all the covers and shields for the mower, just haven't got to it yet. Yea I couldn't complain on the price.
  5. #5
    Join Date
    Mar 2006
    Posts
    57
    Scottdale, PA
    John Deere 3203
    Been working on the 605 trying to get it ready to go and got the 8 hp acme diesel mounted and running. I think I'm going to have some counter balance issues as the diesel is much heaver than the gas engine. Does anyone have to use a counter weight on the attachments to get things balanced right? I know that the sickle bar mowers have this issue.
  6. #6
    Gold Member farmerboybill's Avatar
    Join Date
    Mar 2008
    Posts
    452
    Southwestern Wisconsin
    BCS 850 diesel and 735 diesel
    Usually, a PTO extension or quick couplers are adequate to make attachments balance better. Of course, these make the machine longer. I used to blade snow with a dozer attachment. I drilled a hole in the beam to mount a piece of 1" pipe. I used barbell weights on the piece of pipe. I also did this with the root digger plow. Other than that, I usually just use an extension.
    BCS 850 w/ Kohler Diesel, 30" tiller, 18 inch combined ridger, 36" dozer blade, 28" snow thrower, BCS BIO100 chipper, blade, 38" mower, 26 inch rough cut mower, 36 inch sickle, trencher, 2 way plow, ridger, hiller/furrower
    Deere 60, 3010, 3020, 4010, 4020, 4430, 4640, 4840 and all the implements to work 'em
  7. #7
    Join Date
    Mar 2006
    Posts
    57
    Scottdale, PA
    John Deere 3203
    I haven't attached all the attachments yet nor have I used them all, but the one that's concerning me the most is my 40" lawn mower. It has a hinge pint to allow the deck to be raised or lowered level and with the heaver diesel, its not wanting to sit right as the extra weight of the engine is causing it to raise the whole deck. I don't think an extension will help this as there needs to be more weight on the gearbox shaft to bring the rear of the deck down.
  8. #8
    Join Date
    Mar 2008
    Posts
    167
    The tip end of the mower sits a long way from the wheels and from looking at your picture, it looks like there is a flat place there with sufficient room for bolting down a weight. A twenty pound weight sitting out that far in front of the wheels would likely do wonders at keeping the mower down.
    Bill in NC
  9. #9
    New Member
    Join Date
    Dec 2012
    Posts
    16
    bend, oregon
    ford,pasquali,allis G, bcs, goldoni, ferrari
    I have one of those mowers and I'll take a look at how to add weight to it. I think what Wstr75 said is probably right though. If you don't have a use for that motor I might be interested as I just brought home an 850 w/o a motor or clutch. Thanks
    Jim
Similar Threads
  1. BCS 725 - How does it compare to BCS 722 and BCS 735
    By multimiler in forum Buying/Pricing/Comparisons
    Last Post: 02-27-2013, 03:04 PM
  2. 605 vermeer
    By ken1960 in forum Customization
    Last Post: 01-25-2011, 09:22 PM
  3. BCS Attachments
    By mn_voyageur in forum 2-Wheeled Tractors
    Last Post: 06-28-2010, 07:55 PM
  4. TYM 605
    By ropinghorns in forum Buying/Pricing/Comparisons
    Last Post: 11-30-2008, 01:06 AM
  5. JD 605 loader
    By Ford960 in forum John Deere Owning/Operating
    Last Post: 06-01-2007, 02:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
