Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    New Member
    Join Date
    Apr 2013
    Posts
    24
    madison,ohio
    bcs 735 sc 2400 cub cadet/with loader
    Default Re: new to sight and bcs
    Quote Originally Posted by mkeith View Post
    A common problem is that the tire slips a bit on the rim, pulling the inner tube with it. The valve experiences kind of a shearing force due to the movement between the inner tube and wheel.
    To avoid this problem, fix the inner tube (patch or replace) and always check the tire pressure before operating. Chances are your innertube is bad at the place where the valve comes in. Of course, when changing the inner tube, check the inside of the tire with a rag in case there is some piece of metal or glass stuck in the tire that caused the leak in the first place. (You sound like you know what you are doing, but other people may read this forum after searching or whatever.)
    I've read here on this forum that some people put water in the inner tube to add weight to the tractor. I don't know if slime would interfere with that, but you may want to avoid the slime to keep that option open in the future.
    Personally, I hate slime due to bad experiences with bike tires (it makes a mess if you ever have to deflate the tire).
    One more thing. I've changed two inner tubes. I found the tires kind of hard to take on and off of the wheel without good tire irons. After the first one, I ordered some tire irons from amazon that made the job MUCH easier. Soapy water helps, too.
    --McKenzie
    You are correct it does have tubes so back to the days of patching. I haven't had to do that for some time. It didn't even dawn on me that there would be tubes in there. lmao... Well off to work I go.
  2. #22
    Platinum Member farmerboybill's Avatar
    Join Date
    Mar 2008
    Posts
    783
    Southwestern Wisconsin
    BCS 850 diesel and 735 diesel
    Hey Splitty,
    The tubes can be extremely difficult to find and are highway robbery at a BCS dealership. That, and they don't stock the proper tube anymore. You can only get a tube for a 4-10, and they have to blow up HUGE to fill a 5-10 tire.
    A year ago, I installed a set of new tires on old rims and mounted them tubeless. The holes aren't perfect for tubeless valve stems and they'd leak if you bent them. I slimed the tire and the slime helped a lot. I mounted them on a G85d I sold to a friend (gave him a discount). He's reported back that they work very well and do not leak down.
    BCS 850 w/ Kohler Diesel, BCS 735 w/ Acme diesel, Agrizeta tracks, 30" tiller, Berta double rotary plow, Berta 33" 2 stage snow blower, 18 inch combined ridger, Caravaggi BIO90 chipper, Bellon 32"rough cut mower, Caravaggi stump grinder, BCS 59" duplex mower, Pallidino 20" flail mower, Ravenna trailer, trencher, 2 way plow, ridger,
    John Deere B, 60, 4430 open station, 4430 SGB, 4840, 317 skid steer, and all the implements to work 'em
  3. #23
    New Member
    Join Date
    Apr 2013
    Posts
    24
    madison,ohio
    I saw that the hole in the rim was slightly larger than normal valve stems. If I have to Ill weld them up and drill them the correct size.
  4. #24
    New Member
    Join Date
    Apr 2013
    Posts
    24
    madison,ohio
    I would hate to do that because the factory paint on the wheels is practically mint. I used threaded type valve stem on our stock cars. I wonder if them would work better? I ran the tiller for quite a while today and it performed perfect. That was easily the best 250.00 dollars I ever spent on a piece of equiptment.
  5. #25
    New Member
    Join Date
    Apr 2013
    Posts
    24
    madison,ohio
    I haven't taken the tiller off yet but I want to take it off to start fabricating a trailer for the 735. Should I make a block off plate to cover the shaft where the tiller hooks up?
  6. #26
    Join Date
    Aug 2011
    Posts
    90
    BCS 710
    Joel sells a plastic plate for a dollar. Tractor Accessories
  7. #27
    New Member
    Join Date
    Apr 2013
    Posts
    24
    madison,ohio
    Thanks Bentleg. I knew it shouldn't be left open. I have an old trailer that I am going to retro fit to the tractor in my spare time. Is it as simple as it looks to get the tiller off? Looks like remove to nuts and slide it off. Any other tricks like pull in the clutch and spin around three times? lol..
Similar Threads
  1. BCS Owner's Manual - BCS 722
    By LET-CA in forum 2-Wheeled Tractors
    Last Post: 03-12-2013, 02:47 PM
  2. BCS 725 - How does it compare to BCS 722 and BCS 735
    By multimiler in forum Buying/Pricing/Comparisons
    Last Post: 02-27-2013, 03:04 PM
  3. I'm new to this sight
    By alexanderbuz in forum New Member Introductions
    Last Post: 02-26-2012, 09:43 PM
  4. new to this sight
    By demco in forum New Member Introductions
    Last Post: 05-16-2011, 06:02 PM
  5. Snow Attachments BCS snow blower and BCS lawnmower performance??
    By MikeB2005 in forum Snow Removal
    Last Post: 02-28-2005, 01:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
