farmerboybill
- Joined
- Mar 4, 2008
- Messages
- 783
- Location
- Southwestern Wisconsin
- Tractor
- BCS 850 diesel and 735 diesel
The Del Morino mowers have skids that have bolt holes in them. Moving the skids to different holes makes for different cutting heights. The front baffle also adjusts, but I recommend you just set it to maximum height and not move it again. There has been some concern about the reliability of Zanon mowers. That may be something to consider when buying one. Joel is bringing in a Bellon mower and I have been demoing it. It's very nice, though it's gonna get some deign tweaks.
The Berta flail mower, while more expensive, is a better unit than the rough-cut mowers from Del Morino and Zanon. That removable baffle really makes it a multipurpose mower. Put the baffle in and finely chop the waste in your spent vegetable garden or mow down a cover crop. Take the baffle out and mow paths through the woods, mow rough areas, even mow your lawn. The flail mower is shorter than a rotary mower as well. With a 32 inch rotary mower, you're also going to stick AT LEAST 32 inches out the front. This isn't much of an issue in open, flat areas, but can be a big problem in tight or rough areas.
