Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
  1. #11
    Approved Advertiser
    HayDR's Avatar
    Join Date
    Oct 2002
    Posts
    1,895
    Johnson City, TN
    JD 2040,2240, 2355, 2755, 4055
    Default Re: Sitrex wheel rake-trying to decide
    Quote Originally Posted by Wesdor
    A mechanic I know with many years of experience tells me that the 3pt rakes tend to break teeth when you hit low spots in the field. He strongly recommends getting what I think is being referred to as a dolly mount.
    CCI can you provide any knowledge about 3pt on uneven ground. I respect your knowledge and honesty a great deal.
    The 3 point wheel rakes do work and have done so for 60+ years. They work best when raking in straight lines. What sells them is you can purchase a new one for $600 and rake hay.
    New Holland does still make a roller bar rake that sells new for over $4,000. They will last many years. A good use NH 256 usually sells for $1,500-2,500.
  2. #12
    Join Date
    Aug 2003
    Posts
    1,137
    Welfare Capital of the World...KY
    2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
    That would be $1500 well spent!
    I haven't met anyone other than dealers that sell them that like the single sided wheel rakes. V rakes are a different story altogether. I'm in the market for one of those puppies.
  3. #13
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,359
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Quote Originally Posted by jwcinpk
    Too bad you're so far away. I'd sell you a IH 46 baler and a 4 wheel rake at scrap prices!
    Where are you located? PM me. Thanks
  4. #14
    Approved Advertiser
    HayDR's Avatar
    Join Date
    Oct 2002
    Posts
    1,895
    Johnson City, TN
    In the use of any equipment to operator has the most effect on the end product. Every piece of equipment has a limitation. You will have problems in the long run if you over fill your baler and bale 5 1/2' tall bales if you baler is designed to bale 5' bales. You will have problems trying to rake in circles with a 3 point wheel rake. The tractor turns two feet to the left and the rake is fixed to the rear of the tractor and it goes 2' to the right. This does not happen as quick with a carted rake so you do have some more latitude to rake around corners with V-Rakes.
  5. #15
    Veteran Member JESSE1's Avatar
    Join Date
    Nov 2003
    Posts
    1,311
    Kilgore, Texas
    JD 6400
    I bought a Kuhn SR110 Speedrake two years ago. Does an excellent job and makes quick work of raking.
    Attached Images Attached Images
    6400 John Deere w/ cab, JD 535 Baler, 997 ZTR Diesel, 72" 7 Iron deck, Kubota RTV-X1100C
  6. #16
    New Member jdeere5205's Avatar
    Join Date
    Sep 2007
    Posts
    18
    We bale around 10,000 - 12,000 square bales a year here in Newfoundland, Canada and we have a vicon four wheel rake and thats all we have used for the past 18 years, we have a john deere side delivery but we use the wheel rake much more often. In my opinion it is a great investment for general haying.
    Jamie
    - 5205 John Deere w/521 Loader and Cab, 5205 John Deere w/522 Loader, L235 Kubota w/ 90 loader, Kioti Dk65C w/ Kl 1730 loader, John Deere 7410 w/740 Loader.
  7. #17
    Join Date
    Dec 2007
    Posts
    51
    North Carolina
    2008 Kubota 7040
    Question for those of you that V-rakes.....how wide is the windrow that is produced? We still square bale 90% of what we mow each year and need a pretty tight row for the square baler. Most of the specs that I see on V-rakes state they produce something close to 48" wide which seems really wide to me (great for a round baler, not so much for a square baler). We have always used New Holland rollar-bar rakes but are currently looking for replacements. Looking at both V's and rotarys.
  8. #18
    Approved Advertiser
    HayDR's Avatar
    Join Date
    Oct 2002
    Posts
    1,895
    Johnson City, TN
    Quote Originally Posted by garyfisher123
    A 8 wheel rake will rake a 3' wide windrow. We still put up around 5000 square bales with a New Holland 316 and have no problem with 3' windrow.
  9. #19
    New Member
    Join Date
    Nov 2007
    Posts
    6
    Hay Rake Details2
    H&S builds a really good wheel rake. The 14 wheel Hi Capacity is very easily adjustable for how much hay you gather for a windrow as well as how wide or tight you want your windro.w
  10. #20
    New Member
    Join Date
    Aug 2006
    Posts
    12
    around me you can find the single sided wheel rakes for the price of scrap because nobody uses them. The best feature of a v-wheel rake is that it rakes hay faster than the old fashioned rake.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
