Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Gold Member
    Join Date
    Sep 2008
    Posts
    445
    North East TX
    Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
    Default Which disc for me?
    The only disc I have ever used has been a 6 ft or 8 ft. 3 pt. type. The 6 ft. Ive used was pulled by a small MF or Ford and the 8 ft was pulled by a borrowed Ford (not sure of model, but definately larer than the MF135). I was really surprised how much that 8 ft disc pulled the tractor. Anyway, now I have a Ford 7710 4wd and want to get a disc to use on foodplots. Ive been told by local farmers how much better a drag type disc works than a 3 pt type. However the 3 pt is much easier to manuver in tight areas and get on and off a trailer. What would you say would be the "perfect" disc for my needs. I want to be able to cover some ground but still be able to get through gates and possibly carry with trailer. Would you suggest a good heavy 3 pt or a drag type, also, about what size would fit this tractor setup? thanks
  2. #2
    Super Star Member Egon's Avatar
    Join Date
    Aug 2001
    Posts
    16,629
    Nova Scotia, Canada
    Default Re: Which disc for me?
    It would sound like you have to pick the type of job you want to do and then look for the disk. The size of disk may depend on the diameter of the disk's and total weight put on them.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  3. #3
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    5,684
    Northern California-Tehama Co.
    2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
    Quote Originally Posted by pharmvet View Post
    With the hp you have in that 7710, I'd look for a used 10-13 ft wide wheel disc. Here's mine-- it's an old Minneapolis Moline KA-1300 tandem disc, 13-ft wide, made by Krause for MM. I've removed several outer pans from each axle so my Mahindra 5525 (54 hp engine, 45 hp pto) can pull it on my hayfield.
  4. #4
    Join Date
    Jul 2003
    Posts
    1,993
    MN
    Ford 960, 7700, TW20, 1720; IHC H, 300; Ollie S77
    I pull a 12/19 foot older pull type JD disk with my 7700. The wings fold up, 12 foot or 18 foot. Depends on what i want to do, works well one way or the other. Tho IHC makes better disks....
    Anyhow,w here in the heck would you find a 3pt disk big enough to consider????
    --->Paul
  5. #5
    Join Date
    Sep 2004
    Posts
    246
    Well, if you have to get through gates and want to transport easily on trailer, that will set the upper limits right there.
    How many acres of food plots are you thinking of disking, and how often?
    The 7710 should easily handle a 10-14ft disk depending on soil conditions, terrain and overall weight and style of disk. I have a tractor the same size and use an older Ford 3-pt
    disk that is 10ft wide. It's a model 201 and has 32 blades, 8 on each axle. This disk is a very easy pull for a 7-8000 lb tractor, but it does the job for me. These kind of disks can still be found used and also come smaller. Don't worry if you have to use a disk that is "too small" for the tractor. As long as it covers the wheel tracks and you don't abuse it you will be OK.
    Even a 10' disk should probably be loaded sideways on a trailer or truck, do you really want to travel any distance with something 10' wide?
    Personally I would stay away from a pure drag type disk without wheels. Go for either a wheel disk around 12' or smaller or a 3-point. Used International or Oliver wheel disks are good, or the 3-pt Ford and MF's do a nice job also.
    If you are looking at new 3-point go for the heaviest models. Athens, Hay King, Land Pride, Monroe all make something.
    http://www.hayking.com/3-pt%20Disc.htm
    http://www.hayking.com/pull-type_disc.htm
    http://www.monroetufline.com/product...eries-disc.htm
    I would look for something used and save some money, it's only a disk.
  6. #6
    Gold Member
    Join Date
    Sep 2008
    Posts
    445
    North East TX
    Thanks, Thats just the sort of information Ive been looking for. I have only ever been around 3 pt discs. It seems that if I can get by with a 3 pt. it would solve all sorts of problems for me (loading on trailer, going through gates, less moving parts to maintain,) I guess the real question is : Does a drag type do that much better job than a 3 pt (all else being equal)
  7. #7
    Join Date
    Aug 2001
    Posts
    16,629
    Nova Scotia, Canada
    Seeing as you are going to transport the equipment go for a heavy duty three point and make life easier for yourself.
    If you were actively farming it would be a different matter.
    Egon
    Livin in a
  8. #8
    Join Date
    Jun 2005
    Posts
    5,684
    From what I read here on TBN, there's not a great deal of performance difference between the two types of disc, provided both are set up properly.
    If you need to haul your tractor and disc on a trailer, I'd find the largest 3pt disc available--probably 8-9 ft wide to stay legal when towing. Makes trailoring the disc a lot easier. Something like this
    3 Point Disk Harrow - 8 FT. - Antique Tractor Ads & Info
    or, if you have the bucks, this
    Howse 3-Point Disc Harrow — 7 1/2ft. Width, Model# HT20022 | Disc Harrows + Rakes | Northern Tool + Equipment
    Another approach sometimes used is to convert an 8-9ft drag disc to 3pt. Takes a cutting, drilling and welding, but it can be done.
  9. #9
    Join Date
    Nov 2005
    Posts
    1,032
    Listen to those farmers. I have used several of each, 3 pt, transport (wheel), and pull-type. Each type has a place, but of the (3), I like 3 pt the least because they are the least effective at getting ground ready to plant. They take more hp per foot of width, using more fuel, and require more weight to achieve similar results than the other types. This is because they are constrained and can not follow the ground contour like pull-type or transport. Unfortunately, to fit on a trailer or between narrow gates you may be stuck with that type. I think I would just go with a tiller instead if I had those limitations.
  10. #10
    Elite Member
    Join Date
    Oct 2003
    Posts
    2,762
    the Steernbos (Holland)
    Zetor 3011, Zetor 5718
    3 meter, or 10ft is the standard size used here, with tractors like your 7710
    The pulling behaviour of the disk shouldnt matter if you set it up right. If you have a chain for a top link, or put a slotted plate instead of a hole on your disks top link bracket, it should follow the ground contours just like a pull type.
    You might want to loosen the 3pt lift arm stabilisers in the field, to make it seek its own line of traction, instead of pushing your tractor straight ahead when you steer.
    With a floating top link pin, and the 3pt stabilisers loose, it should behave as a pull type and require the same hp. When you constrain it to run straight behind the tractor, it cant compensate the lateral forces between the front and rear disks so you'll be forcing it out of its natural path, causing the increase of power requirement: the same as a poorly setup moldboard plough. Some people have trouble pulling the same 16" three furrow moldboard plough with 90hp, as i pull with 50hp, because their trackwidth is wider, and they dont set up the plough head accordingly and force it to run under an angle with the stabilisers. That takes lots of power, and countersteering.
    Since you plan to trailer it to the field anyways, you dont have to slacken and tighten the 3pt stabilisers between fields anyways.
    Free scrap is a good investment !!!
    “The worst enemy of life, freedom and the common decencies is total anarchy; their second worst enemy is total efficiency” · Aldous Huxley
    __________________
    1967 Zetor 3011, restoration in progress: Technically new, just needs the cosmetics..
    1973 Zetor 5718, home made loader
    1998 Volvo S70 TDI
    2007 Volvo 440 1.9 TD based dirt buggy, needs time !
Similar Threads
  1. Advice on disc harrow and planter
    By Blu 82 in forum Owning/Operating
    Last Post: 07-07-2008, 11:50 AM
  2. Mundane operating questions for 6.5 foot disc
    By Z-Michigan in forum Attachments
    Last Post: 05-14-2007, 12:42 PM
  3. King Kutter heavy-duty disk
    By PAMike in forum Attachments
    Last Post: 02-09-2007, 09:58 PM
  4. Help with Digital Pics Disc Error!
    By Jagmandave in forum Related Topics
    Last Post: 10-05-2005, 02:01 PM
  5. Wheel disc/3-point disc switch-er-oo
    By Indydirtfarmer in forum Attachments
    Last Post: 04-06-2005, 09:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
