BryanM
Gold Member
Ok the topic Tedding! I purchased a well used Duetz Fahr 4 basket tedder. And am not sure If I am using it right. I have a manual and tilt the baskets down to touch or barely touch the ground and run pto upto 540 rpm.
The problem is I Seem to be windrowing as I tedd instead of spreading the hay out evenly. I have tried differant travel speeds and differant tilts too the tedder. What am I doing wrong?
More questions do I go the same way as I cut, with the windrow? When do you tedd?
