ModMech
As some may recall, we own a small farm near Canton, TX. We are having troubles getting our field of good quality hay harvested on shares, even $1/bale is out of the question!
So, we are thinking that if we buy our own equipment, we might not actually make a profit, but at least we'll keep our AG exepmtion and pay for the equipment over a few years (2-3). We have a B2410 tractor, that will cut the field with a 7' sickle and rake it, but not bale it. We are trying to get a 30-40 PTO HP tractor on the cheap and there are a number of good prospects.
We found a JD 224W and two JD pull-type rakes for $4500, I'm feeling that since we don't know if the baler works and the rakes are only "ok", $3500 is a more resonable price.
There is a local NH 311 that needs timing and adjustment for $1k, what do you think about that? It seems like there is something we are missing, if it needed only minor repair it should sell for more?
There are a number of IH 46 balers in the $1200 - $1500 range but none can be tested and I hear the "old IH balers don't tie well". How about the 46? Some TBN posts indicated these were ok, just don't want to buy something and have fits with it.
We found a NH Hayliner 268 for $1500 (twine) that is reported to be "barn stored and in good condition", might look if that is a GOOD price as it is a hike to get there.
We are generally thinking along the following lines:
The pull rakes in working condition should be in the $500-$600 range, more if in good or "nice!" condition obviously and less with flat tires and missing tines etc.
The JD 224W is a good baler, but will need some maintenance after sitting up for a number of years and we can't see it make a bale, maybe $2500?
The IH balers are larger(?) than we would really want, and I am very worried about parts availability. For $1200 or so, maybe worth it?
The NH 311 would be a steal if it could be repaired as suggested w/o a lot of $$$ in parts. I am a mechanic, so the labor is not an issue and it's relatively close.
There are few sickle mowers around, we found one pull-type (pto driven) for $190 but it is a LONG drive to even look at it and there are no photos of the important parts.
We typically get 3-5 cuttings and 600-1000 bales/year from our meadow, but we would *like* to have good enough equipment to have the option of cutting others fields near-by.
Any advice is MUCH appreciated!
