Results 1 to 10 of 12
10-20-2010, 10:44 AM #1New Member
- Join Date
- Oct 2010
- Posts
- 1
- Tractor
- 5000 Ford
Delco one wire alternator installation on 5000 Ford
What do I have to change in the wiring to hookup a delco one wire alternator on a 5000 ford gas tractor 1965 model. all help appreciated thanks Joe
10-20-2010 10:44 AM # ADS
10-22-2010, 11:00 AM #2
Re: Delco one wire alternator installation on 5000 Ford
BX23TLB & RTV1100 with 72" Power Angle Plow
10-22-2010, 08:32 PM #3Elite Member
- Join Date
- Aug 2004
- Posts
- 2,758
- Location
- North of Mtl,Que,Can (Ste Adele)
- Tractor
- MT180D
I once converted from 6 to 12 volts on an old jeep.
Never changed the starter, it just cranked faster and started sooner.
Besides the alternator I did change all light bulbs however.
Naturally the ignition coil needs to be adressed as well.
10-23-2010, 05:24 PM #4
You can do this ONCE it's converted to 12V, but not before.
As to how to wire it in, that is as easy as any wiring job gets.....
Remove (pull out) or tie-back and tape all but the main battery B+ wire from the old group of wires to the alternator. Install the Delco, then connect the B+ wire (12V connected to battery) to the B+ stud on the alternator. You are done!
The regulator in the Delco draws a *very* small amount of current at all times and it will charge automatically without any additional wires.
Battery + -> Alternaor B+ and that's it.JohnG
We have Democracy, but were founded on Liberty.
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote - Benjamin Franklin (1706-1790).
I am for LIBERTY!
I Support electric trailer brakes on EVERY axle over the towing vehicle's GVW, CDLs for RVers and safety inspections on ALL licensed vehicles!
10-23-2010, 10:21 PM #5Silver Member
- Join Date
- Sep 2006
- Posts
- 136
- Location
- ohio
- Tractor
- kabota
Because of the slight daaw i ran mine through a oil pressure switch and then to the battery.
10-23-2010, 10:52 PM #6
JD 790 w/70 FEL & 7 BH on turf tires
JD 455 w/60" MMM & 54" front blade
10-23-2010, 11:40 PM #7New Member
- Join Date
- Oct 2010
- Posts
- 11
- Location
- Ms.
I have been planning on converting my 12v, '71 5000 but don't quite understand what to do with the wires going to the voltage regulator and the generator. I think I could find the B+ connected to the regulator. Also is there any problem with oil press and temp gages working. Any suggestion on a size/model no. that wont stick out to far from the hood panel.
10-24-2010, 01:18 AM #8
it is already 12volt from the factory
10-24-2010, 11:13 AM #9Super Member
- Join Date
- Jun 2005
- Posts
- 5,720
- Location
- Northern California-Tehama Co.
- Tractor
- 2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
My 1964 Massey Ferguson 135 diesel has a one-wire Delco alternator. Here's the wiring diagram I made when I disassembled the tractor for restoration.
You have to run the engine up to 1800 rpm or so to polarize the alternator get it to start charging the battery--one of the peculiarities of the one-wire alternator.
Good luck with your project.
10-24-2010, 04:43 PM #10Silver Member
- Join Date
- Aug 2009
- Posts
- 182
- Location
- loganville ga
- Tractor
- wheel horse c-100
if you will call your local alternator rebuilder ask him to get you the generator to alternator bracket kit it is sold by a company calll jimco. if this cannot be done please call me i can get it for you it will be about $35 to $40 very easy to install with this kit. as wiring goes all you need is a goold solid hot wire to pos post on alternator and off you go it is also advisable to get as small o/d pulley you can find this will allow the alternator to turn on at very low rpm as does on most farm tractors run. my number is 678-478-7427
good luck
mitch becton
Similar Threads
Removing barbed wire fence
By Anonymous Poster in forum ProjectsReplies: 30Last Post: 12-30-2011, 12:19 PM -
Need help with a wire schematic for a Ford 1700
By wilsonbus in forum New Holland Ag TractorsReplies: 3Last Post: 09-27-2010, 10:47 PM -
69 Ford 5000 Fender
By jcalla in forum New Holland Owning/OperatingReplies: 4Last Post: 07-02-2010, 05:25 PM -
Ford 5000 and IH 480 disk hyd qd
By Fred Smith in forum HydraulicsReplies: 8Last Post: 08-05-2009, 05:46 PM -
Ford 5000 Alternator Conversion
By El_Gato in forum New Holland Owning/OperatingReplies: 3Last Post: 01-24-2007, 09:43 AM
