Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Aug 2010
    Posts
    1
    135 Massey Ferguson
    Default 135 MASSEY FERGUSON AG3-152 Oil Leaks
    Have change the rear seal on the crankshaft several times and I still have the tractor leak oil at the cotter pin behind the oil pan.
    Need some expert help on correcting this sisuation Has anyone had this problem
    and how do I correct?
    Have done this several times have replace all the gaskets that are require for this operation , like the gasket inbetween the oil seal housing and the rear oil seal also the oil pan gaskets. Is there a way to find out the correct seal for the housing?
  2. #2
    Advertiser sweettractors's Avatar
    Join Date
    Jul 2003
    Posts
    7,616
    Central Kentucky
    JD 6403 CHA-JD 3130 CHA
    Default Re: 135 MASSEY FERGUSON AG3-152 Oil Leaks
    I have went through what you have done a few time myself with about a 50-50 chance of success. This seems to be related to the main bearings being loose and ruining each new seal as soon as it is put in. Short of a major rebuild on the engine lower end, Put some Lucas in and drive on. I think you are fighting a losing battle. Ken Sweet
    http://www.sweetfarms.com/
    Sweet Farm Equipment LLC (Internet Sales, Shipping All States)
    Shipping Facility
    1815 Defries Rd., Canmer, Ky 42722 Toll Free 1-866-528-3323
    Ken Sweet sweet@scrtc.com
    Shipping Example: Can ship 800 lbs from Ky. to Dallas for $165
    The Northeast shipping corridor is a little more expensive.
  3. #3
    Platinum Member MFRED's Avatar
    Join Date
    Mar 2006
    Posts
    954
    Connecticut
    MF 5435, MF 165
    Yup, bearing roll.
    That or it's the transmission leaking and you're fixing the wrong problem.
  4. #4
    Veteran Member jlsmith's Avatar
    Join Date
    Aug 2010
    Posts
    1,263
    Murchison, Tx.
    MF 285 Long 560 MF2670 CX100
    Change your oil pan gasket. I ran into the same problem and it was the oil pan leaking threw into the weep hole. Tore it down 3 times before someone told me about that and it hasnt leaked since.
Similar Threads
  1. Oil & Fuel Massey Ferguson 1260 oil filler plug?
    By krumph in forum Massey Ferguson Owning/Operating
    Last Post: 12-09-2014, 06:11 PM
  2. 1962 Massey Ferguson 50 input needed
    By Saggydog in forum Massey Ferguson Owning/Operating
    Last Post: 05-31-2012, 09:43 PM
  3. Massey Ferguson oil fill cap location
    By odette in forum Massey Ferguson Owning/Operating
    Last Post: 09-28-2010, 11:02 PM
  4. Global Warming News
    By KB9UDE in forum Rural Living
    Last Post: 03-11-2010, 09:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
