Results 1 to 4 of 4
  1. #1
    Join Date
    May 2005
    Posts
    1,119
    Eastern WA
    Jinma JM354
    Default 4 row JD 71 Flex Planter seed hoppers planting corn
    I may have the wrong planter for what I'm trying to do. I plant six fairly small gardens, all corn. All areas are half acres. The hoppers are so big that for the small amount of seed corn we plant it barely cover the bottoms. Are there aftermarket hoppers that are smaller so the seed is a little higher and will find the drop hole to the plate discharge. With seed prices like they are No One could ever afford to fill those giant hoppers. It's a pretty cumbersome operation trying to maneuver a small utility tractor and plant straight rows and make sure the seed is going down the discharge plates. What brand or make of planter do you guys use to plant corn? bjr
  2. #2
    Veteran Member D7E's Avatar
    Join Date
    May 2006
    Posts
    2,251
    manitoba
    Many
    Default Re: 4 row JD 71 Flex Planter seed hoppers planting corn
    When coming to the end and trying to use up all the seed in the hoppers i usually ride on the planter for a few runs or if it's dark throw in more than i need then clean out after and use next year !
  3. #3
    Veteran Member Luremaker's Avatar
    Join Date
    Aug 2004
    Posts
    1,250
    Ontario
    Kubota L3130HST & NH TC18
    Quote Originally Posted by bjr View Post
    At an auction, a few years back, I did see an insert inside a fiberglass hopper, around the size of a large coffee can. I am sure it was used to reduce the amount of seed needed in the hopper while planting. You might look for a tapered pail or bucket and cut off the bottom so that if fits inside the hopper.
  4. #4
    Gold Member
    Join Date
    Feb 2008
    Posts
    293
    Default
    Quote Originally Posted by Luremaker
    I saw in the owners manual that they had vegetable seed hoppers. This is whatyou could use
Similar Threads
  1. Planters JD 71 Flex Planter Gauage Shoe?
    By bjr in forum Attachments
    Last Post: 05-21-2010, 11:25 AM
  2. JD Corn Planter. 1440?
    By Conn in forum Attachments
    Last Post: 05-01-2010, 07:10 PM
  3. Seeders John Deere 71 seeder
    By napabavarian in forum Attachments
    Last Post: 01-30-2007, 03:37 PM
  4. Seed Plates For Allis Chalmers Corn Planter
    By rfawkes in forum Parts/Repairs
    Last Post: 04-27-2005, 09:03 AM
  5. Corn spacing
    By JonLeonard in forum Rural Living
    Last Post: 06-06-2002, 11:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
