Hay rakes and tedders
   / Hay rakes and tedders #1
jwcinpk
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
I'm in the market for a new v rake or rotary rake and a bigger tedder. The dealer I have done most of my purchasing from in the past only has Rhino brand and only 10 wheels. I hadn't heard much about Rhino rakes in the past so I thought I'd post here. Is Rhino a good brand rake? Are others of the same quality cheaper? How do rotary rakes compare in price and quality?
Next is tedders. I have a sitrex and have had 0 problems with it in 7 years. Is Rhino on the same quality level with sitrex?
I just want to get the best bang for my buck in atleast an 8 wheel v rake or comparable rotary and a good 4 basket tedder. Both would need to be hydraulic fold.
   / Hay rakes and tedders #2
i have a sitrex 8 wheel rake and i like it.it is about 15 years old .i have overloaded it in real heavy hay so i would not want a 10 wheel.i think sitrex equipment is sold under several brands,rhino may be one.compare some pictures.
   / Hay rakes and tedders #3
Just a warning about the tedders, I've been told that the cheap 2 basket tedders have no problems, but the 4 basket versions of the same are not as rugged.
Are you suggesting that Sitrex or Rhino is a cheap tedder? I've not priced either brand yet...wanted to hear from folks using them first.
Also there are 2 different v rakes available...one is an ER and the other SWR...what's the difference?
   / Hay rakes and tedders #6
I've been looking at 4-basket tedders, too. I've got a 2-basket NH, that's a real beast! Too heavy, and it can really beat the leaves off of the hay! :mad:
Have a Kuhn rotary rake that is the cat's PJ's! Will move heavy, hay into big, tall windrows! No twisting or roping - and the air just moves!!! :thumbsup:
Got a quote for the HD model Kuhn; think it's the 5202 model - $7,100. They've got a 0% financing program right now, too.
Don't know alot about Sitrex or Rhino, though.
AKfish
   / Hay rakes and tedders #8
I just got a new Vermeer WR20 8wheel rake $2500 hay rake.jpg,been seeing alot of Kuhn lately,havent ever got to use anything other than the Vermeer...
   / Hay rakes and tedders #9
I just got a new Vermeer WR20 8wheel rake $2500 View attachment 264334,been seeing alot of Kuhn lately,havent ever got to use anything other than the Vermeer...
How does a wheel rake like that compare to a side delivery rake?
Been looking at adding a 2nd side delivery rake and a dual rake hitch, but that would run almost the same price as that wheel rake (minimum of $2000 to buy the rake and hitch), running one side delivery rake too slow at times whenw e need to merge several light rows.
Aaron Z
   / Hay rakes and tedders #10
Aaron Z
I can only go off what I have heard that the rake you are using get less dirt in the windrow. In years with several different folks baling are place have never seen anything but a wheel rake used,and when I baled years ago I only ran wheel rakes. I guess most use them cause its low priced and gets the job done but I would bet if gonna sell horse quality hay would wonna use something like you have or the big dollar pto rake. I found a vid [ame]http://www.youtube.com/watch?v=aeIoeGG4PEM&feature=player_detailpageeo[/ame]
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
WACKER NEUSON EZ36 EXCAVATOR (A52705)
WACKER NEUSON EZ36...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
