Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Gold Member CTPhil's Avatar
    Join Date
    Nov 2009
    Posts
    258
    NW CT
    Default Re: Plastic twine for round baler
    Quote Originally Posted by blueriver View Post
    You should have a monitor that will mount to the tractor ... How many hydraulic hose's do you have?
    I have two hose that plug into the tractor for the tailgate and a set of wires that plug in for the electric tie ... therefore the monitor so I can tie the bale.
    Thinking about it maybe you have hydraulic tie and hydraulic tailgate and need two rear hydraulic remotes ... I quess then maybe a monitor would not be needed.
    I've got 2 pair of hydraulic hoses, no monitor.
    Ford 2600, Ford 4100, Ford 3550 Industrial Loader, 1949 Case VAC, 1951 Case VAC, 7 assorted Gravely L Models, Gravely Commercial 10, Gravely 524, Gravely 5460...
  2. #12
    Elite Member blueriver's Avatar
    Join Date
    Oct 2007
    Posts
    3,700
    S.E.Oklahoma
    JD 5520 Montana 4340 Farmall Super C
    Quote Originally Posted by CTPhil View Post
    Sounds like Hydraulic tie ... just have to watch the bale gauge on the baler.
    "When selling a lifetime ... don't sell it short"
    auctioneer@southernauctionco.com
  3. #13
    Join Date
    Jan 2009
    Posts
    1,523
    Rushville, Ohio
    Massey 180 Diesel
    For curiosity sake, I went to Case/IH,and looked up your baler. In the exploded view in the pic below, it shows an audible alarm (#15).
    Might be an idea to get a manual for your baler through Case/IH. I've referred to mine more then several times for adjustments, belt repair, etc. Well worth the money...
    My deere has manual site gauges for each side of the bale. The more even you keep them when baling, the easier it is to finish with a nice even bale...
    Although I have made a few barrel looking ones, and some lopsided ones along the way... Acutally, I like the "loppies" for stacking on the first tier, so the second tier doesn't kinda' lean out.., LOL...
    Attached Thumbnails Attached Thumbnails Plastic twine for round baler-001csih-84489.gif
  4. #14
    Join Date
    Nov 2009
    Posts
    258
    NW CT
    No audible alarm, but the previous owner said the baler starts to "sound different" when getting full.
    I did get a manual from eBay, got it yesterday.
    Just got back for TSC with some twine.
    I suspect I'll be back for more help as I go, if anyone else wants to put in their experiences, please do!
  5. #15
    Join Date
    Feb 2009
    Posts
    938
    NC
    Wife and son use Orangeline plastic, I think 10,000' rolls in the JD 448 Round Baler but have always used sisal in the 24T sq. baler.
    '11 John Deere 5065M /cab
    '10 Kubota L3940 w/FEL
    '09 JD X720
    '91 CaseIH 5140 Maxxum w/cab
    '78 IH 686 w/M&W Turbo 106 PTO hp w/canopy
  6. #16
    Join Date
    Nov 2009
    Posts
    258
    NW CT
    I took the baler out for the first time yesterday, it was pretty much a train wreck! The pickup plugged immediately, and several times thereafter. Getting a bale started was difficult, is this a matter of technique? The twine cutter failed to cut at all, I had to cut every one with a pocket knife. I was able to make even bales OK, but didn't pick up the windrow cleanly, I'm sure that was just me. I've got several bales with no twine because I made them too big and the baler wouldn't spin any more for wrapping.
    I'm pretty sure most of the problem was me, am I just that stupid or is there a steep learning curve with these things? It seems like making this work requires quite a bit of operator skill, is that right? The twine not cutting has to be a mechanical issue, right?
    Any thoughts would be appreciated, I'm pretty discouraged at this point.
  7. #17
    Join Date
    Oct 2007
    Posts
    3,700
    S.E.Oklahoma
    Sorry ... but I started chuckling out load and my wife asked whats so funny ... I read the post to her and she said "Bring Back Memories" ... Yes to all your questions it is a steep learning curve!!
    Plugging can be anything from not entering the windrow straight, baling against the lay of the hay, hay too wet or too dry (dry hay is slick) and hard to start ... chain may be off the pickup reel ... twine cutter, did you clean it? They can get a gum build up from the poly twine ... did you sharpen it ... is it adjusted with the right tension ... if you didn't pick up the windrow the pickup reel was not low enough ... I had to build hitch extension to lower my draw bar by 4" other wise the teeth could not reach the ground. OR are you saying the windrow was too wide and the baler left hay? Bales too big ... gotta watch that bale size quide on the side of the baler and stop before its maxed out.
    Practice ... the more hay you roll the better you will get.
  8. #18
    Join Date
    Nov 2009
    Posts
    258
    NW CT
    Thanks for the reply. The pickup height was fine, but I wasn't starting square to the windrows. Yes, the windrows were large, but the missing was mostly because I'm calibrated for a small square baler, and my baler doesn't have gathering wheels. The hay was indeed quite dry and did feel quite slick. The twine knife did seem clean and sharp but I'll look again. The knife isn't on the anvil when the twine arm is "home", it seems like it should be?
    Thank you for the encouragement and perspective.
  9. #19
    Join Date
    Oct 2007
    Posts
    3,700
    S.E.Oklahoma
    Those wide windrows with out gathering wheels are tough to get all the hay ... just bring them together tighter when you rake ... The twine kinda slides along the cutter blade ... even though its a small blade just a couple inches long it enters on the one end and as it passes along the blade it cuts. Anytime mine doesn't cut I usually just pass a small thin file along the bottom of the blade between the sharp side and the flat plate at the angle of the cutting edge ... I guess that cleans and helps the cutting edge and then I move on with no problems.
  10. #20
    Join Date
    Nov 2009
    Posts
    258
    NW CT
    I'll try filing, thanks.
Similar Threads
  1. jd 214t baler
    By donais in forum Ag Tractors & Machinery
    Last Post: 05-22-2011, 02:48 PM
  2. square baler parts
    By moetr in forum Attachments
    Last Post: 08-28-2010, 01:14 AM
  3. Baling Twine
    By barrybro in forum Haying
    Last Post: 06-13-2009, 04:28 PM
  4. Sisal and Plastic twine prices on the increase
    By HayDR in forum Rural Living
    Last Post: 12-16-2005, 08:29 AM
  5. Sisal and Plastic twine prices on the increase
    By HayDR in forum Buying/Pricing/Comparisons
    Last Post: 12-14-2005, 09:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
