Page 3 of 3 FirstFirst 123
Results 21 to 21 of 21
  1. #21
    Gold Member BeeferMan's Avatar
    Join Date
    Jun 2008
    Posts
    325
    North Central MA
    Case 1194, Ford 641, NH TT75A
    Default Re: Plastic twine for round baler
    I find our 8420 can be plugged when starting a bale if you feed too much hay in before the bales starts spinning. You have to be careful of hay that is slightly moist - like if it has a bit of dew on it, or real dry. Feed hay evenly across the width of the pickup and make sure that it's all being pulled into the bale chamber. As soon as the bale starts spinning then it's pretty hard to plug it, it'll suck up about anything.
    If yours is the manual twine tie like our 8420, then the cutter is not very reliable. You're right that the twine doesn't stay on the anvil. I made a hook to keep the twine where the knife could cut it, I posted pictures here some where. But later I found that Case/Hesston actually made one too (much more expensive than mine!) - part #700117238, "ROD - twine, guide" in the diagram below. If your baler doesn't have one, that could help. (Sorry, that's a crappy picture, the guide is in the lower right - you can see the full size picture on Messicks parts site)
    Here's a couple shots of the fix I made. Pretty simple, you just have to make sure the twine arm clears the hooked pin...
    Plastic twine for round baler-8420mod1small.jpgPlastic twine for round baler-8429mod2small.jpg
    Attached Thumbnails Attached Thumbnails Plastic twine for round baler-8430_threader.png
    Case 1194, NH TT75A, Ford 600, Bobcat A300, balers, rakes, mowers, tedders, spreaders and lots of other toys as well...
    - Jim
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
Similar Threads
  1. jd 214t baler
    By donais in forum Ag Tractors & Machinery
    Last Post: 05-22-2011, 02:48 PM
  2. square baler parts
    By moetr in forum Attachments
    Last Post: 08-28-2010, 01:14 AM
  3. Baling Twine
    By barrybro in forum Haying
    Last Post: 06-13-2009, 04:28 PM
  4. Sisal and Plastic twine prices on the increase
    By HayDR in forum Rural Living
    Last Post: 12-16-2005, 08:29 AM
  5. Sisal and Plastic twine prices on the increase
    By HayDR in forum Buying/Pricing/Comparisons
    Last Post: 12-14-2005, 09:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
