Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Member Sraczi's Avatar
    Join Date
    Mar 2008
    Posts
    29
    Default
    Just finished ~120 small squares with a Kioti CK25HST and JD24T. Left the FEL to add overall weight (3700 lbs) and ran in Low gear. The 20hp PTO worked well- ground was flat and didn't have any major rocking motion. If Zz says it will work- you'll be fine!
  2. #12
    New Member
    Join Date
    Feb 2012
    Posts
    10
    Dayton, TX
    Mahindra 4025 4wd
    Default Re: NH 282 baler
    did you ever pick up this baler? I have a mahindra 4025 4wd and found a good deal on a used NH 282 baler with a NH 438 cutter and 256 rake and was wondering if my tractor could handle it.
  3. #13
    Member
    Join Date
    Aug 2011
    Posts
    25
    NH 282 baler-dsc03293.jpg here is my set-up,,, Abrietta baler..only requires around 20 pto..I pulled it with my 28hp JD 870. I do 50 acres per yr.
Similar Threads
  1. ih 706 282 engine hp?
    By succor in forum Case-IH
    Last Post: 10-14-2011, 11:46 PM
  2. Comparison NH 5070 Baler vs Case IH SB541 Baler
    By bondboy in forum Buying/Pricing/Comparisons
    Last Post: 08-18-2011, 02:33 PM
  3. Price Check 1948 New Holland 282 Corn Sheller
    By MapleMeadow in forum New Holland Buying/Pricing
    Last Post: 07-08-2011, 11:10 AM
  4. L4330 for sale 282 hrs.. many attachments
    By smwelden in forum Kubota Buying/Pricing
    Last Post: 09-04-2006, 10:16 PM
  5. Snow Cub Cadet 282 Snow Blade Attachment
    By cubcadet282 in forum Cub Cadet Yanmar & CUTs
    Last Post: 10-28-2005, 05:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
