Results 1 to 3 of 3
07-23-2012, 01:30 PM #1New Member
- Join Date
- Jul 2012
- Posts
- 1
- Location
- villisca, iowa
- Tractor
- john deere
348 jd baler
have 348 twine baler that has a intermenent needle problem it may do 20 or do 400 bales then will leave needles up in baler. Can pull needles back to home and it will reset itself and run for awhile again with no problems need info on problem as dealer has no ideas on a square baler
07-23-2012, 01:57 PM #2Platinum Member
- Join Date
- May 2008
- Posts
- 767
Re: 348 jd baler
There is an arm that cycles the needles follow it up and it is attached to a cam type of device on the outside of the baler. Something is worn so it is not fully cycling the needles. There should be a large gear that has a ramped step inside of it. When the knotter trips a bearing should drop against this ramp and cycle the needles. I would think the bearing is slipping from this ramp and stopping. This would be if you haven't broken a shear pin.
It's been a while since I have worked on one of these, going by poor memory. That is how I remember it, I may not be explaining it very well..
08-05-2012, 12:24 AM #3
Similar Threads
JD 348 square baler
By Bigfoot62 in forum John Deere Owning/OperatingReplies: 6Last Post: 08-16-2010, 07:12 PM -
Does JD 328/338/348 Baler Model Matter?
By chetlenox in forum John Deere Ag TractorsReplies: 28Last Post: 07-07-2010, 11:43 AM -
2007 JD 348 Square Baler Tongue Question...
By dirtdeveloper in forum AttachmentsReplies: 0Last Post: 02-22-2010, 07:45 PM -
John 348 Square Baler - no go with a 4720?
By ddivinia in forum John Deere Buying/PricingReplies: 27Last Post: 07-25-2009, 08:29 AM -
John Deere 348 Square Baler - good deal?
By ddivinia in forum John Deere Ag TractorsReplies: 10Last Post: 07-31-2006, 11:45 AM
