Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Sep 2012
    Posts
    2
    Reardan, WA
    Hesston 8090
    Default Hesston FEL
    Looking for a Front end loader for a Hesston 8090. My research not turning up anything...
  2. #2
    Elite Member
    Join Date
    Sep 2003
    Posts
    3,945
    New Brunswick, Canada
    Kubota L5030 HSTC, MF 5455
    Default Re: Hesston FEL
    Alo/Quicke should have brackets for one, check with a dealer, they don't publish their fitment guide online.
  3. #3
    New Member
    Join Date
    Sep 2012
    Posts
    2
    Reardan, WA
    Hesston 8090
    Thank you. I'll check it out!
  4. #4
    Veteran Member Bigfoot62's Avatar
    Join Date
    Aug 2008
    Posts
    1,290
    W. Central Louisiana
    JD 5085M; NH TN70A; Ford 2600
    Might also look here: Koyker
    '10 JD 5085M Cab MFWD FEL
    '07 NH TN70A MFWD FEL
    '81 Ford 2600
    JD 457 round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
    My other tractor is a '95 Kenworth.
    Don’t ever wrestle with a pig. You’ll both get dirty, but the pig will enjoy it.
  5. #5
    Gold Member rdbigfarmboy's Avatar
    Join Date
    Jan 2005
    Posts
    329
    Collinwood, TN
    Best I remember all the fiat tractors that size had the utility tractor frame meaning a set of bolt holes in front of the front axle and another behind and then nothing much to bolt to at the bell housing. so it would have to be attached at the rear axle. so your needing a sub frame that runs from the rear axle to the front attachment points.
    Can you do any work yourself or do know someone that can?
    A sub frame to fit will cost about as much as a used fel.
    I have seen the new mid mount smaller loaders at different sites and auctions for 600 to 1500. But they have not mounting brackets or methods of attachment.
    If you can build a subframe then alot of loaders will attach to the tractor.
    so look European if you want new. Fiat is Case New Holland and other brands but they wont all fit.
  6. #6
    Platinum Member Hoosier Hay Man's Avatar
    Join Date
    Nov 2008
    Posts
    542
    Indiana
    Kioti DK45S Cab, Quicktach FEL
    Default
    Try Westendorf. They make a Great Loader.
    http://www.loaders.com/aspx/selector/selector.aspx
    They have a listing for Hesstons.
    Thanks,
    HHM
    Tractors include 2009 Kioti DK45S Cab, 1974 JD4430, 1952 Oliver 77, 1953 JD50, 1940 JD A, 1938 Farmall F-14,
    NH 489 Haybine, NH 315 Baler, Gehl 1465 Round Baler, NH 68 Baler, Kuhn GA301 GM Rake, Kuhn GA25 Rake/Tedder, JD 851 Rake, GT-77 ATV Herd Seeder,
    Everlast PowerArc 200
  7. #7
    D7E
    D7E is offline
    Veteran Member D7E's Avatar
    Join Date
    May 2006
    Posts
    1,940
    manitoba
    Many
    Depends what you want to pay ..I would be looking at wreckers ? Good tractor but you will have a tough job in north america !
  8. #8
    Platinum Member Dead Horse's Avatar
    Join Date
    Feb 2009
    Posts
    575
    New Hampshire
    Try sourcing in Canada, particularly Quebec. Those tractors were very popular there and I see plenty of them in the eastern townships between Vermont and Montreal.
    I have a 100 90 DT with the loader. Awesome machine.
    Attached Thumbnails Attached Thumbnails Hesston FEL-porsche-run-2006-006.jpg   Hesston FEL-scan_pic0002_001.jpg   Hesston FEL-march-2008-021.jpg
    "We a two tractor family"
Similar Threads
  1. Hesston PT-7 mo/co
    By MoMike in forum Ag Tractors & Machinery
    Last Post: 12-08-2011, 10:01 PM
  2. 566 Hesston
    By Scurryfarmboy in forum All Other Brands
    Last Post: 11-11-2011, 07:01 PM
  3. hesston 140-90
    By diamondc in forum Parts/Repairs
    Last Post: 04-30-2011, 06:33 PM
  4. Fiatagri (Hesston) FEL
    By Dead Horse in forum Attachments
    Last Post: 08-30-2010, 06:25 PM
  5. Hesston Tractors
    By Dead Horse in forum Ag Tractors & Machinery
    Last Post: 03-21-2010, 01:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
