Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Gold Member SLHawkins's Avatar
    Join Date
    Nov 2007
    Posts
    435
    Northern Virginia
    John Deere 5403, International Harvester 584
    Default Re: Need some help identify this fertilizer/lime spreader?
    I got the new tires in and mounted them yesterday. Why is it that sometimes stuff does not want to go back together and easy as it came apart?? One of the wheels just flat out refused to go back on the axle. I tried both sides and got the same result. It would slide on except for the last シ or so. I even took a sledge hammer to it, nothing. It was if a ridge had formed (the sledge hammer might have done that actually). But, after a few swipes inside the hub with a file, I was finally able to get it back on.
    Need some help identify this fertilizer/lime spreader?-fertilizer-spreader-001-jpgNeed some help identify this fertilizer/lime spreader?-fertilizer-spreader-002-jpg
    A lil bit country, and a whole lotta soul, wid a taste of hip hop flava on the side.
    JD 5403, , IH 584, NH 846 Baler, NH 492 Haybine, Woods E320 Batwing Rotary Cutter, Landpride RCR1572 Rotary Cutter, WR Long 72" OBRG, LandPride RB3596 Landscape Blade, '74 Diamond Reo Dump Truck; '70 F880, '94 Freightliner Classic, KNC 10 tooth Chisel Plow, New Holland Manure Spreader, 35' Texas Bragg Flatbed Gooseneck, Case 450 Track Loader, H-90CM Wheel Loader, '69 Kaiser Jeep M52A2 6x6
  2. #12
    Join Date
    Nov 2007
    Posts
    435
    Northern Virginia
    This spreader works great! It spread the lime a whole lot better than I expected. It took me probably around 2 hours to spread 6 tons over about 5 acres. I did not have any clogs, not too much dust (just a little), and loading it was fairly easy. The hopper holds several hundred pounds, if not a half ton at least. I recommend a drop spreader for anyone with a small acreage field looking to spread ag-lime in the powdered form.Attachment 304414Attachment 304415Attachment 304416Attachment 304417
    http://youtu.be/MpvdYJ6HyHs
    Hawk
Similar Threads
  1. Lime Spreader
    By foggy1111 in forum Attachments
    Last Post: 08-15-2013, 03:12 PM
  2. Lime and Fertilizer spreader help
    By Mitigator33 in forum Projects
    Last Post: 08-09-2011, 05:58 PM
  3. Sq Ft measurement for lime and Fertilizer
    By BizDoc in forum Rural Living
    Last Post: 09-01-2007, 09:14 PM
  4. Spreader lime/fertilizer spreader questions
    By JohnnyDark in forum Attachments
    Last Post: 04-29-2005, 09:40 AM
  5. Ag Lime Spreader
    By Laminarman in forum Build-It Yourself
    Last Post: 09-07-2004, 08:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
