Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Gold Member SLHawkins's Avatar
    Join Date
    Nov 2007
    Posts
    399
    Northern Virginia
    John Deere 5403
    Default Need some help identify this fertilizer/lime spreader?
    Howdy folks,
    I picked this up yesterday from a nice fella up in Pennsylvania. The red looks to be its original color. The wheel pattern is a 5-spoke star. It is ten feet wide. I did not see any data plate or any thing with a make and model number. It is in great shape (well, it does need a little TLC). After getting it to the house, I had to free the metering gate on the bottom. It was caked with old fertilizer and dirt. After a little banging with a hammer, some oil, and scraping with a chisel, the metering gate now slides freely back and forth. One of the axles was locked too. Again, a few shots of grease, and some rocking backing and forth of the wheel, it broke loose too. I got the wheels off becuase the tires are completely shot. Once I get those replaced and back on, then I'll be laying down the lime. I would like to try and get a manual or something though to make sure I got the settings right.
    Thanks.
    Hawk
    Attached Thumbnails Attached Thumbnails Need some help identify this fertilizer/lime spreader?-fertilizer-spreader-002.jpg   Need some help identify this fertilizer/lime spreader?-fertilizer-spreader-003.jpg   Need some help identify this fertilizer/lime spreader?-fertilizer-spreader-004.jpg   Need some help identify this fertilizer/lime spreader?-fertilizer-spreader-005.jpg   Need some help identify this fertilizer/lime spreader?-fertilizer-spreader-006.jpg
    A lil bit country, and a whole lotta soul, wid a taste of hip hop flava on the side.
    JD 5403, , IH 584, NH 846 Baler, NH 492 Haybine, Woods E320 Batwing Rotary Cutter, Landpride RCR1572 Rotary Cutter, WR Long 72" OBRG, LandPride RB3596 Landscape Blade, '74 Diamond Reo Dump Truck; '70 F880, '94 Freightliner Classic, KNC 10 tooth Chisel Plow, New Holland Manure Spreader, 35' Texas Bragg Flatbed Gooseneck, Case 450 Track Loader, H-90CM Wheel Loader, '69 Kaiser Jeep M52A2 6x6
  2. #2
    D7E
    D7E is offline
    Veteran Member D7E's Avatar
    Join Date
    May 2006
    Posts
    1,940
    manitoba
    Many
    Default Re: Need some help identify this fertilizer/lime spreader?
    It's a grass seeder is'nt it .??
  3. #3
    Advertiser sweettractors's Avatar
    Join Date
    Jul 2003
    Posts
    6,859
    Central Kentucky
    JD 6403 CHA-JD 3130 CHA
    Quote Originally Posted by D7E View Post
    These are called "drop seeder/spreaders" and will spread seed, ferterlize, dry lime, dry litter or a combination of any of these materials mixed together. I have been using these for over 50 years. Ken Sweet
    http://www.sweetfarms.com/
    Sweet Farm Equipment LLC (Internet Sales, Shipping All States)
    Shipping Facility
    1815 Defries Rd., Canmer, Ky 42722 Toll Free 1-866-528-3323
    Ken Sweet sweet@scrtc.com
    Shipping Example: Can ship 800 lbs from Ky. to Dallas for $165
    The Northeast shipping corridor is a little more expensive.
  4. #4
    D7E
    D7E is offline
    Join Date
    May 2006
    Posts
    1,940
    manitoba
    Many
    Never seen lime put through one ..Amazing it works !
  5. #5
    Join Date
    Jan 2009
    Posts
    1,514
    Rushville, Ohio
    Massey 180 Diesel
    They work sooo much better if the lime is right out of the crusher..!!
  6. #6
    D7E
    D7E is offline
    Join Date
    May 2006
    Posts
    1,940
    manitoba
    Many
    Having worked for lime spreading contractors i would never imagine you could get it to feed enough volume of product ?
  7. #7
    Gold Member
    Join Date
    Jul 2003
    Posts
    283
    Western NY
    My dad bought a drop spreader for lime many many years ago (I think I was maybe 12-13). If the lime was bone dry, it worked fine. If it was the least bit damp, well he then had me ride the spreader and whack the side near the openings with a rubber mallet whenever it clogged, which was quite frequently. We struggled with it for one spring only. That fall, he bought a tandem axle, 2yd(?) broadcast unit and never looked back. No comparison between the two.
  8. #8
    Join Date
    Jul 2003
    Posts
    6,859
    Central Kentucky
    Dry or pelletized lime works best. Ken Sweet
    Shipping Facility
  9. #9
    Gold Member
    Join Date
    Jan 2011
    Posts
    261
    IN
    Kioti CK30, JD X475. HPX Gator, Woodmizer LT10
    Possibly a Gandy brand?
  10. #10
    Join Date
    Nov 2007
    Posts
    399
    Northern Virginia
    John Deere 5403
    Quote Originally Posted by TractorTidy View Post
    The hopper looks very similiar to both the Gandy and Ford Dearborn/New Holland Models I have come across. However, the metering lever on those models were different than the lever on this one. If I can't locate a manual, I reckon I'll just trial and error it.
    I have read threads both for and against these types of spreaders. Key is making sure it is dry. The main reason I went with this spreader was I having a hard time getting someone to come out and spread lime on my small field (only 5 acres). I'll see how it does. I do have a spin spreader where I could use the pelletized lime, but I can get ag-lime for a little over $11/ton versus several dollars per bag (adding to over $1000) for the pelletized.
    Hawk
Similar Threads
  1. Lime Spreader
    By foggy1111 in forum Attachments
    Last Post: 12-06-2012, 10:18 AM
  2. Lime and Fertilizer spreader help
    By Mitigator33 in forum Projects
    Last Post: 08-09-2011, 05:58 PM
  3. Sq Ft measurement for lime and Fertilizer
    By BizDoc in forum Rural Living
    Last Post: 09-01-2007, 09:14 PM
  4. Spreader lime/fertilizer spreader questions
    By JohnnyDark in forum Attachments
    Last Post: 04-29-2005, 09:40 AM
  5. Ag Lime Spreader
    By Laminarman in forum Build-It Yourself
    Last Post: 09-07-2004, 08:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
