Lockport
Gatorblades. I had one on a Snapper, a pair on a Kubota LT, adopted triples on a Kubota BX with reduction adapters and finally found ones that nearly matched the size needed for this cutter. Of the hundred (+/-) Gatorblades that Oregon puts out for a variety of decks, they all have the cutting edge on the same side. If you've never used a Gatorblade, do yourself a favour.
This gearbox is reversible and that's what it will take to make this finish mower cut a proper lawn. I hope to have the only properly functioning Bobcat 3FM72 in existence.
