I have a question about the setup of an offset disc. Overall length of the rear gang is 131". The front gang length is 121" On the right side of the rear gang, the gang sticks out from the frame 44", on the left side it is 19.5". On the front gang, the right side sticks out 24", and the left gang sticks out 29" from the frame (see drawing). what i would like to do is shift the gangs so that the distance from the end of the gang to the frame is equal on both sides of the gang. The 44" stick out on the right rear makes manuvering difficult. Is there a reason why the gangs are set up this way? Should I just live with the inconvenience?
thank you, Carr
thank you, Carr
