Results 1 to 4 of 4
  1. #1
    Join Date
    Oct 2004
    Posts
    66
    Chester - UK
    International 484
    Default New toy
    Well it's new to me.... and hopefully will be a great toy when it's fixed!
    It's a Case 4230 (80hp) I found in a 'damaged repairables' yard not far from here. I've spoken to the dealer who sold it new (1996) and he has confirmed that it was in good mechanical condition before a car ran into it taking the front axle off.
    When the front casting/axle broke away it broke the [tombstone] casting and the engine block making it an insurance write-off.
    I've sourced replacement engine block, sump (oil pan), tombstone, front differential (the pinion broke on the original one) and have an agricultural engineer lined up to strip the original engine and rebuild it using the new block.
    Total cost including a new door, gaskets, labour, etc. will be around £4000 ($7000). The tractors are selling for between £8500 and 10,000 in the UK right now.
    Attached Images Attached Images
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Join Date
    Oct 2004
    Posts
    66
    Chester - UK
    International 484
    Default Re: New toy
    This is what I'm hoping it will look like when it's put back together! Compact, light 4wd with some creature comforts - being out in the open is not always enjoyable in the UK [img]/forums/images/graemlins/frown.gif[/img]
  4. #3
    Join Date
    Jun 2002
    Posts
    1,044
    Southwest PA
    Deere 4710/reverser, JD 318 (still needs TLC), JD LT160
    Default Re: New toy
    Ouch! Looks like a perfect case for "you should see the other guy". Good luck bringing her back to a useful life.
  5. #4
    Gold Member
    Join Date
    Mar 2002
    Posts
    419
    Bolivar, pa.
    power trac 422, and agco-allis 5660, john deere 550 dozer ,1845 power trac
    Default Re: New toy
    What did the car look like????
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
