Results 1 to 6 of 6
  1. #1
    Join Date
    Jul 2005
    Posts
    579
    West Texas
    JD 5325 JD 5203 JD 2320 LT 133
    Default 1086 International
    I have a 1086 International that was my Dad's. It is locked in reverse and am hoping its not a major repair.
    Does anyone on TBN have one of these tractors?
    Thanks much
    G. Bates.
  2. #2
    Member
    Join Date
    May 2004
    Posts
    37
    Sw MN
    Default Re: 1086 International
    Remove the cab floor, you will see the shift linkage. Should be able to wiggle them back into gear. Check the bolts where the shift gos into the trans, they like to come loose.
  3. #3
    Join Date
    Jul 2005
    Posts
    579
    West Texas
    I appreciate it much. Will see what I come up with.
    Hope you have a good year. [img]/forums/images/graemlins/smile.gif[/img]
  4. #4
    Veteran Member Birdhunter1's Avatar
    Join Date
    May 2004
    Posts
    1,341
    Murphysboro, IL
    Ford 3910
    Don't knowif it's the saem set up but i was workgin in a 986 not too long ago that did that, I pried on the shift lever in the cab and it came out. The big collar that moves between park and reverse moved into park while the lever moved towards the forward gears (I tried to shift fast) . Pried it back to the center positon between park and reverse and all was ok!
  5. #5
    Super Star Member Kyle_in_Tex's Avatar
    Join Date
    Oct 2002
    Posts
    11,170
    Giddings, Texas
    JD 4310,JD5420
    This is caused by loose or worn shift linkages. I am told that you can get an old pocket knife and try to pry one of the linkages away. The gears are overlapped that shouldn't be. It may help to have the tractor on flat ground with no load on the gears.
  6. #6
    Join Date
    Oct 2004
    Posts
    1,401
    Georgia
    With all my older IH question and parts needs we use the Bates Corp. , they are a older IH one stop shop! Good luck with yours.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
