Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Member ponderingjunkman's Avatar
    Join Date
    Dec 2010
    Posts
    34
    south durham, NY
    Pasquali 462e
    Default New Pasquali owner
    So this poor, unloved Pasquali followed me home. Says "D 38 Power Tug" on the dash. From what I have found, it was a military airplane tug. Hopefully it won't mind cutting grass and hauling maple sap. I'll try and document the process of getting it going again. It seems to have an injector hanging open, and a wheel seal is leaking, and parts are missing, and it seems to have been unloved. I'll see what I can do...
    Attached Thumbnails Attached Thumbnails New Pasquali owner-pasquali-001-jpg   New Pasquali owner-pasquali-002-jpg   New Pasquali owner-pasquali-003-jpg   New Pasquali owner-pasquali-004-jpg
  2. #2
    Join Date
    Mar 2008
    Posts
    1,188
    southwest NH
    Kubota L5240
    Default Re: New Pasquali owner
    Looks like a fun project , good luck ! She's lucky you took her in!
    'Master of a thousand indispensable skills destined to keep him at the poverty level'
    'You can't beat a man at his own trade'
  3. #3
    Join Date
    Apr 2009
    Posts
    178
    Jefferson, ME
    Pasquali 988
    Ive got a 988 Pasquali, they run great, an air cooled diesel is the oddest thing but they are powerful. It looks odd without the sheetmetal on it. Theres a guy in NH that is the rep for USA for Pasqualis. He knows his stuff but it can take a LONG time getting parts from him.
  4. #4
    Join Date
    Dec 2010
    Posts
    34
    south durham, NY
    Pasquali 462e
    Yes, it has the 3 cylinder Lombardini diesel. I've seen lots of duetz air cooled diesels, but this italian is the first i've seen. There is alot I haven't seen... I have the fenders and hood and front headlight piece, but they are dented and rusty- savable, but unloved. Doesn't seem to be much use on the thing- note the uniform tire tread. Thanks for the replies!!
    More pictures!!
    Attached Thumbnails Attached Thumbnails New Pasquali owner-pasquali-005-jpg   New Pasquali owner-pasquali-006-jpg   New Pasquali owner-pasquali-007-jpg   New Pasquali owner-pasquali-008-jpg
  5. #5
    Join Date
    Apr 2009
    Posts
    178
    Jefferson, ME
    Pasquali 988
    If you end up needing a master brake cylinder its a Wilson racing unit that fits on it as pretty much a direct replacement. I can get teh part number off of mine if your interested.
    Do you know it it has standard rims or the wide rims? Mine also has truck tires on it as one of the AG tires on it tore and I cant find a replacement for it.
    I really want to get the wide rims and wide floatation tires for it but I cannot find a source for them.
    ~ Phil
  6. #6
    Join Date
    Dec 2010
    Posts
    34
    south durham, NY
    Pasquali 462e
    mp- I don't know if the rims are standard or not, and i keep forgetting to look at the size- i'll check. The brakes are an area needing attention- so the master cylinder # would be great, Thanks!
  7. #7
    Join Date
    Jan 2009
    Posts
    140
    South Central, PA
    Kioti DK 45SE, 993 Pasquali
    Just noticed this post, welcome to the Pasquali club. They are definitely unique little tractors that are capable of getting alot of work done.
    The tractors you guys both have must be newer than mine, as for brakes mine just has the old pedal and rod mechanism no hydraulics to speak of. Also, mine has the Ruggerini diesel in it not the Lombardini and is a model 993. Currently it has a front end loader and a backhoe off of a kubota BX23 that we adapted.
  8. #8
    Join Date
    Dec 2010
    Posts
    34
    south durham, NY
    Pasquali 462e
    Thanks, David, for the welcome! My hydraulic brakes are on the back axle only- no evidence of front axle brakes. How much can your loader lift?
    The model number on mine is 462E. I have no idea what year it is...
  9. #9
    Join Date
    Apr 2009
    Posts
    178
    Jefferson, ME
    Pasquali 988
    To put anything of weight in the FEL you need weight in the back. I bough a 3pt hitch carrier that I build a box on to carry wood in. I also layed several cement blocks in the bottom of it so it has several hundred pounds in it all the time. When I loaded it with wood I noticed I need to be careful turning as with the weight of the FEL and turning sharp it will lift the outside front wheel. Jack recommended 750 lbs in the back to use the FEL for dirt. Ive picked alot of weight up with it of gravel. I also have a spade adapter I can connect onto the FEL, its like a giant shovel and digs really well.
    Mine has regular truck tires on it as one of the AG tires has a tear in the sidewall. Id really like to get a set of the wide floatation tires as I have some wet land and it sinks.
    The newer units with hydraulic brakes I think Jack said is a model 988. I have a typed manual that someone converted an Italian manual to english, but has no pictures. If you guys are interested I can try scanning and sending as a file to you.
  10. #10
    Join Date
    Dec 2010
    Posts
    34
    south durham, NY
    Pasquali 462e
    It has been a while, but progress has been made on our tractor! As the pictures show- it is ready for use!
    Attached Thumbnails Attached Thumbnails New Pasquali owner-tractor-sap-040-jpg   New Pasquali owner-tractor-sap-041-jpg   New Pasquali owner-tractor-sap-042-jpg
Similar Threads
  1. Previous Owner Stupidity
    By arrabil in forum John Deere Owning/Operating
    Last Post: 09-11-2010, 01:06 PM
  2. new 273 owner today!
    By Gregster613 in forum TYM Owning/Operating
    Last Post: 06-29-2010, 08:41 PM
  3. Replies: 30
    Last Post: 05-29-2010, 10:26 AM
  4. Pasquali 991
    By Taylortractornut in forum All Other Brands
    Last Post: 10-02-2009, 09:13 PM
  5. First Time Tractor Owner LB1914
    By Geoscouter in forum Kioti Owning/Operating
    Last Post: 09-21-2007, 11:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
