Results 21 to 30 of 42
12-12-2011, 10:08 AM #21
12-12-2011, 10:41 AM #22Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,133
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: ford 861 powermaster
a bit toung in cheek.. but flails generally take more hp and are slow on a given cut, thana given rough cutter. to make up for speed, you need more hp, / larger mower. then you run ingo problems on them swales and ruts you mentioned.
a dual flail setup say.. 2 4' flails.. I have seen of a ford industrial tractor.. like a 3400 or 3500.. it ran slow, but did ok.. a 6' bush hog would have out cut it though...
soundguy
12-12-2011, 11:30 AM #23Gold Member
- Join Date
- Jan 2011
- Posts
- 489
- Location
- Westmoreland County PA
- Tractor
- Fords
I guess I should clarify my comment. I would not recommend a flail mower either. I don't like them for the reasons already mentioned.
I am suggesting a front mount rotary mower. Jacobson, Toro, Kubota, New Holland, John deere, all make them. They range from around 20 to over 50 horsepower. You mentioned that you plan to mow weekly or bi-weekly. If you are mowing that often, you do not need a brush cutter. No exageration, a front mount will run circles around any tractor on smooth regularly cut ground. They also come in 4x4, if you have wet areas.
If the ground is pretty rough, then go with a tractor. I just don't know why you would cut every week or two if the ground was too rough for a front mount.
12-12-2011, 11:41 AM #24
I need to clarify my need. Not only do I have to finish cut common areas, I also have to mow a dozen 1 acre lots 3-4 times a year. The grass and weeds on those lots is about 2 feet high when I mow....so really looking for a dual purpose tractor/mower combo if possible to handle these jobs....plus I would like to plow snow...so FEL is desireable.
Originally Posted by strum456
All this tractor and mower research is making my head and eyes spin !!
12-12-2011, 12:19 PM #25Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,133
- Location
- Central florida
- Tractor
5' hog plus a 7' finish mower.. get a unit with power steering and a simple 2 post loader with hyd bucket.
soundguy
12-12-2011, 02:40 PM #26Gold Member
- Join Date
- Jan 2011
- Posts
- 489
- Location
- Tractor
- Fords
I'd go for a 6' hog. You can always raise it up a little or take less on a pass if you need to. 5' impliments work ok on 800s, but don't allow for much overlap, even with the wheels the whole way in.
For your finish mowing, you need to decide what kind of a job you want to do. If you want lawn-like results, get a front mount or a zero turn unit. If you are limited to getting just one machine, then a 7' finish mower would be my choice (in addion to a bush hog for the tall stuff). In my opinion, you should really have two machines for the use that you described.
As for the FEL, keep in mind that you will not want it on the tractor when you are mowing. Not only does it make the machine less manuverable, but it is way harder on the front of the tractor. If all you are doing is snow plowing, maybe you could have someone fabricate a mount for you to attach a power angle truck type plow. My father in law had one on an 861 he used to have, and it sure was slick.
One last bit of advice: No matter what tractor you use for hogging, make sure it has a good grill guard. Mine is a factory bumper that I added on to. Radiators are expensive!
12-15-2011, 09:28 AM #27Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,488
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
I have a 861. Its a good old tractor but some things to look at on any old iron is 3 point lift, steering slop, ect.
I would not want one with a FEL. Modern tractors with power steering and 4 wheel drive are the only way to go for loader work.
25 acres on a 861 is going to take some time. I did 8 acres last fall on a neighbors 961 and 6' hog and it took quite some time.
ChrisLast edited by Diamondpilot; 12-15-2011 at 04:13 PM.
12-15-2011, 09:40 AM #28
Thanks for the info....I have talked my self out of my love for the 861 already. Now looking for good Used or new JD or KUB which could handle all this work.
12-15-2011, 11:44 AM #29Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,133
- Location
- Central florida
- Tractor
12-15-2011, 11:45 AM #30
Similar Threads
Ford Excursion - I think I must have one! Comments welcome.
By ddivinia in forum Trailers & TransportationReplies: 83Last Post: 08-16-2009, 09:50 PM -
861 Ford Problems
By kf4uda in forum Ford Vintage TractorsReplies: 6Last Post: 08-11-2009, 11:01 AM -
Ford 801 powermaster Injector pump and wiring.
By baronthered in forum Ag Tractors & MachineryReplies: 4Last Post: 06-19-2009, 02:58 AM
