Page 30 of 43 FirstFirst ... 202728293031323340 ... LastLast
Results 291 to 300 of 427
  1. #291
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    8,059
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Default Re: any toro groundsmaster fans on here?
    Sounds like a good deal.
    Have you measured the actual difference in circumference between the old and new tires?
    You must have a late model 325D to have the two-way clutch. Let us know how it works with the new tires.
    Hold "Ctrl" (Control) and click on a picture or a Link, to open it in a new Tab.
    My Avatar, the TORO+Loader:
    Kwik-Way FEL and TORO Groundsmaster Put Together
    V417 Compact Telehandler: ​(This replaced my tractor): The best machine to do what I need a machine to do
  2. #292
    Gold Member
    Join Date
    Aug 2016
    Posts
    307
    Wytheville, VA
    Toro 325-D 4WD
    Drove it on concrete to check for binding traction, with no apparent issues. I have 3/8in clearance on the left side fender (in front of tool box), and about the same to the inside (outside of frame).
    Quick question... I just replace the trans (whole assembly), and I'm having one heck of a time bleeding the steering and lift circuits. About a half gallon of fluid and some bubbles later, still no power steering and lift. Both worked fine before I replaced the trans. Any advice?
  3. #293
    Gold Member
    Join Date
    Aug 2016
    Posts
    307
    Wytheville, VA
    Toro 325-D 4WD
    Quote Originally Posted by Xfaxman View Post
    No circumference measurement, but here are some pics (the scrub marks are from having to move it with the old flat tires, not from the new ones):
    Mine is a '98 model. They listed an option for 10.50 width tires in the manual and optional wheels (12x10, I think)... but mine had the standard 128.
  4. #294
    Elite Member
    Join Date
    Feb 2012
    Posts
    4,324
    NE Indiana
    1710 Ford, Versatile 150
    Those tires look good on there - but maybe a little tight?
  5. #295
    Gold Member
    Join Date
    Aug 2016
    Posts
    307
    Wytheville, VA
    Toro 325-D 4WD
    Quote Originally Posted by Creamer View Post
    Maybe...
    I wouldn't limp them around on low pressure.
    I tried them out on a wet incline and a soggy runoff area. Great traction and flotation.
    Only issues I have experienced are turf damage when turning sharp from sidehill to uphill climb (easy enough to avoid), and a somewhat reduced ride quality. My old turf tires had some give, but were old and worn out. With the weight of my flail deck and the stiffer tires, downhill on rough grade gets a bit jerky on fore/aft weight transfer... not enough to lift the rears, but enough to make my worn out Grammar seat uncomfortable after 6 or 7 acres of hillside
  6. #296
    Elite Member
    Join Date
    Feb 2012
    Posts
    4,324
    NE Indiana
    Quote Originally Posted by MultiMow View Post
    Maybe...
    Roughness - another reason to run them flatter. What you are feeling is them going up on a cleat and then off.
  7. #297
    New Member
    Join Date
    Jun 2006
    Posts
    13
    any toro groundsmaster fans on here?-ebay-pump-jpgFinally got the Hydro problem on my 325D fixed. The pump was getting too weak to lift deck and hard to steer.
    Instead of taking it out over the winter, bought a EBay pump for a spare, $430. It looked so good ,decided to
    just try it. Just primed it with clean oil, and swapped. It works great ,now lifts deck even at lowest throttle, and
    steers soo much easier. Happy Mowing
  8. #298
    Gold Member
    Join Date
    Aug 2016
    Posts
    307
    Wytheville, VA
    Toro 325-D 4WD
    Not really. On the flats, they're fine. Only on rough terrain headed downhill do I feel any difference. When I say "rough", I mean steeply sloped pasture with drain lines and cow paths. On the normal bumpy (not maintained "turf"... just normal field mowing) they're great.
  9. #299
    Gold Member
    Join Date
    Aug 2016
    Posts
    307
    Wytheville, VA
    Toro 325-D 4WD
    Quote Originally Posted by crazycarl View Post
    Nice catch Carl. A working transmission with a good charge pump will usually fetch around the $700 mark. A refurb will run around $1,600. If you're lucky enough to find a new unit (I was told by Sauer-Sundstrand they don't make them anymore) they're about $2,000+.
  10. #300
    Gold Member
    Join Date
    Aug 2016
    Posts
    307
    Wytheville, VA
    Toro 325-D 4WD
    Thought I'd share my latest find, with you guys...
    My replacement flail deck!
    That's not water shining... It's OEM paint!... and she's dirty, at that!
    I still have two 72" recycler decks for sale, my old flail deck, and a 2wd 328D with 2nd gen Cozy Cab (wider model) with working fan and full light package, auxiliary front hydraulics, and 3 rear suitcase weights.
Similar Threads
  1. FEL, TORO Groundsmaster Put Together
    By Xfaxman in forum Customization
    Last Post: 05-16-2018, 07:30 PM
  2. It was a TORO GROUNDSMASTER 217D
    By JoBy in forum Customization
    Last Post: 08-21-2013, 12:54 AM
  3. Toro Groundsmaster for pasture maintenance?
    By QRTRHRS in forum Toro / Wheel Horse
    Last Post: 02-21-2011, 08:16 PM
  4. Toro Groundsmaster 52 or 62
    By dholly in forum Toro / Wheel Horse
    Last Post: 11-12-2010, 12:50 PM
  5. Any Neil Young Fans Here?Tom Petty fans?
    By CountryBoy in forum Rural Living
    Last Post: 08-06-2003, 11:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
