Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Bronze Member ghitch75's Avatar
    Join Date
    Jul 2004
    Posts
    71
    bloomfeild indiana
    a/c wd45,mf1250
    Default fixin' up the gator
    i put brake lights,backup lights,1" lift,brush guard and camo kit on the gator...goin' to order under body armor....already tore a CV boot....next will be a little bigger tires....should i go with 27's?
    Attached Thumbnails Attached Thumbnails fixin' up the gator-camo-xuv-1-jpg   fixin' up the gator-camo-xuv-2-jpg   fixin' up the gator-camo-xuv-3-jpg   fixin' up the gator-camo-xuv-4-jpg
    07 JD XUV 620i 4X4
    1954 AC WD45 wide front
    Case 580c Extend Hoe
  2. #2
    Join Date
    Dec 2004
    Posts
    2,273
    western NC
    JD 2320; 4520
    Default Re: fixin' up the gator
    27" tires are nice; your Gator will have a tough time powering them if you have any real hills and want to go reasonably fast. I run different sized tires in the front and back and that did fine, and going diesel really helped. If you go oversized you might wish to consider a small lift kit; I went 1.5", which seems plenty. In short, going oversized looks good, but your machine will perform better with the gas engine if you leave the tires and wheels the stock size.
    John M
  3. #3
    Join Date
    Jul 2004
    Posts
    71
    bloomfeild indiana
    a/c wd45,mf1250
    i put a 1" lift to the front raised it about 1 3/4"....so you think i should stay with 25's with some meaner tread?...i hope someday they come out with a higher HP chip for the gassers...
    07 JD XUV 620i 4X4
  4. #4
    Join Date
    Dec 2004
    Posts
    2,273
    western NC
    JD 2320; 4520
    Everyone has a different opinion here, so I cannot speak for all, but I can say based on my experience. The larger, more aggressive tires on my XUV get more traction than do the stock tires, by a fair amount. I love them in mud and the winter snow. I like them less in the summer when I am doing a lot of riding on pavement and less work where traction is imperative. A larger circumference tire on your XUV will lug the engine when climbing steep hills or long grades. If you live where it is flat or where the grades are short, this fact might not matter much to you. It did to me. More aggressive tread will definitely help traction, but unless you are running in deep mud or snow or bad terrain often, I do not personally think it is worth changing from the factory tread. The traction might be better, but the ride most likely will not. Despite opinions to the contrary, the stock tires get pretty good traction and ride better than most aftermarket brands. If you find an aftermarket tread that rides and wears as well, it probably will not get enough better traction to merit a change. My dealer, who helped me customize my Gator, frequently puts aftermarket wheels on the machines when he builds them up. Unless someone wants aggressive and oversized, he replaces the wheels but mounts the stock tires as he says he has found no aftermarket tire that offers any better combination of ride and traction for most buyers.
    John M
  5. #5
    Join Date
    Jul 2004
    Posts
    71
    bloomfeild indiana
    a/c wd45,mf1250
    i live in the hills of southern indiana and it's hilly!!!.....we had 12" of snow 2 week ago and it went like a tank!.......after the snow melted i had it back on the neighbors where it was logged in the summer and i was very happy with the way it went in mud it was like drivin' in grease...so i guess this tires aren't to bad....
    07 JD XUV 620i 4X4
  6. #6
    Join Date
    Dec 2004
    Posts
    2,273
    western NC
    JD 2320; 4520
    If you want to see a picture of my Gator XUV gas, search Gator pictures and go to my post from 4/2007. My diesel one looks just like it but has 1/2 less lift. It would give you an idea what things would look like
    John M
  7. #7
    Veteran Member nmu98's Avatar
    Join Date
    Jun 2007
    Posts
    1,130
    JD 5203, JD 3720, JD 4110, JD 445, IH 1586, IH 886, IH 404......
    I had some 26" mudlites on my honda rubicon. They did rob some power, but were nice meaty tires. I have no clue on how powerful the gas engine is, but may 26 inch tiores might get you a little size, without crazy power loss?
    Any aftermarket mud tire is going to be heavier than what you have, so ???? Maybe you would see a loss?
    I know that I don't like to go places with my gator where it might get stuck... Mostly in deep snow... Its a bear to get back out after it burried to the frame!
  8. #8
    Join Date
    Jul 2004
    Posts
    71
    bloomfeild indiana
    a/c wd45,mf1250
    Quote Originally Posted by jcmseven View Post
    John M
    i looked at your pic's...very nice!!!!
    what brand and size tires are those?.....i like them!!!
    btw what did the dealer do to get 40 mph over yours?....and where is this dealer?
    07 JD XUV 620i 4X4
  9. #9
    Join Date
    Oct 2005
    Posts
    129
    hey, where did you get the brake light switch?
    Is it a John Deere part or did you improvise something?
    Also, where does it go, inside the master cylinder or under the pedal?
    I want to setup brake lights on my gator so I don't get smoked taking out the garbage at night. I was thinking of doing running lights, but if there is a brake switch I will do that.
    Also, I recommend going with a set of fender guards on the front. They are pretty cheap and offer good protection. We put ours on after barn staff smashed the front fender on a door or gate or something.
  10. #10
    Veteran Member TOMMYHPX4X4's Avatar
    Join Date
    May 2005
    Posts
    1,956
    schriever, louisiana terrebonne parrish
    gator hpx 4x4
    i got a used bumper if your interested in it? no dents or nuthin i don't think you could dent it anyway . it has lights too.
    This ignore feature is great it's like raid is on pest one click and the pest is gone
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
