Results 1 to 10 of 15
06-25-2009, 09:37 AM #1
Go Kart will not get moving
I just picked up this 6.5 hp go kart on Craigslist last night. It is in great shape and not even two years old. It is extremely fast, almost hard to control it is so fast, once it gets going. My problem is that it has a little trouble starting to move. I do not have any experience with these things so I am hoping someone around here does. Could it be that the belt needs replacing? It makes a little squeal when you push the gas and if you give it a little push with your foot on the ground it will start moving and then it will get up to speed. If I look at the engine I see the small wheel spinning when the gas is pressed but the belt does not catch and spin the big wheel until you get it rolling.
Thanks in advance for any advice you might be able to give me.Kubota L3830 GST
06-25-2009, 09:40 AM #2Veteran Member
- Join Date
- Aug 2005
- Posts
- 1,020
- Location
- Guernsey Co. Ohio
- Tractor
- Ford 3000
Re: Go Kart will not get moving
If the current belt isn’t loose, it sounds like it could use a new one.
06-25-2009, 09:53 AM #3
06-25-2009, 10:24 AM #4Veteran Member
- Join Date
- Aug 2005
- Posts
- 1,020
- Location
- Guernsey Co. Ohio
- Tractor
- Ford 3000
If the belt is slipping, it certainly could be a worn belt. They don't always look bad.
06-25-2009, 11:10 AM #5Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,491
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Some of the belts are asymmetrical, which means unequal sides. Symmetrical belts sides are equal. The belt may be on backward. Someone might have put the wrong belt on it. also , the clutch might be on it's way out. Just put it up on blocks, and take the shield off so you can see what is happening.
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
06-25-2009, 03:03 PM #6Gold Member
- Join Date
- Feb 2006
- Posts
- 316
- Location
- Phoenix AZ and offgrid weekend place south of Prescott
- Tractor
- John Deere 4500 and Mule 3010 (gas)
If belt is OK, then my guess: Centrifical clutch shoes/friction surface worn.
RavensRoost
06-25-2009, 04:32 PM #7
Please look at the attached picture with the red arrow. The arrow points to the wheel that starts spinning immediately when the gas pedal is pressed. It just spins without grabbing the belt and therefore the rear wheel doesn't spin. Is this how it would behave if the clutch is going out?
Kubota L3830 GST
06-25-2009, 04:44 PM #8Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,491
- Location
- JACKSONVILLE, FL
- Tractor
Yes, that is the clutch. Just take it apart and look at the clutch material, the springs might be missing, see if the the clutch material is worn out.
J.J.
Git er done.
06-25-2009, 04:54 PM #9
Thanks everyone. I'll try to look at this tonight and report my findings.
Kubota L3830 GST
06-25-2009, 04:57 PM #10Gold Member
- Join Date
- Feb 2006
- Posts
- 316
- Location
- Tractor
Actually, if the springs were worn or gone I would expect the symptom to be the clutch is always engaging and likely also stalling motor at low speed. Doesn't mean he couldn't have BOTH spring issues and bad shoe/friction material though ;-)
RavensRoost
