Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    May 2006
    Posts
    12
    Default 2008 XUV 4WD problem
    I use my Gator on a farm in fields. When it is in 4 wheel drive it works fine going forward. If I stop and put it in reverse, it seems like it is bound up, and when you back up it seems like the front wheel kinda drag and aren't going the same speed as the rear ones. You can see where the left front wheel kinda tears up the grass when backing up. It is really hard to turn when going backwards. I then stop take it out of 4wd, and go forward a few feet and then I can back up with no binding. It has 200 hours, and I'm just a old guy who putts around the farm fixing fences, and cutting wood. It is the gas model. It has done this for a long time. I only use the 4wd when going through wet areas, and take it out as soon as it is safe. Of course the dealer went out of business the day after I bought it, and its a long ways to the next one.
  2. #2
    Join Date
    Apr 2007
    Posts
    220
    OC, OREGON
    JD 2320
    Default Re: 2008 XUV 4WD problem
    Quote Originally Posted by shyguy6 View Post
    You can go to any JD dealer for warranty work. I would take it in, and have someone look at it..
    JD 2320
    200CX
    62D
    MCS
    And other stuff...
  3. #3
    Join Date
    Nov 2003
    Posts
    98
    Western Wisconsin
    I had the same problem or something similar on a 06 HPX. The dealer service dept test drove it and couldn't replicate the binding. They did verify that something in the tranny has to pop back when shifting from 4wd to 2wd, and it causes a snapping twack noise, which they claim is normal. I heard that regularly when shifting.
    I now have a 2010 XUV (a 2009 delivered in Feb 2010, so they called it an 2010). It has the same twack noise when shifting 4 to 2wd. Haven't had the binding though (yet?).
    Didn't like that binding -- it prevented the steering from being free to go stop-to-stop. The unit then would plow forward in a turn.
    jim
  4. #4
    Veteran Member JESSE1's Avatar
    Join Date
    Nov 2003
    Posts
    1,059
    Kilgore, Texas
    JD 6400
    Make sure you don't have the differential lock engaged. It's hard to steer going forward with it engaged and nearly impossible to steer going backwards.
    6400 John Deere w/ cab, JD 535 Baler, 997 ZTR Diesel, 72" 7 Iron deck, John Deere 855D 4x4 Diesel Gator
  5. #5
    Member
    Join Date
    Oct 2009
    Posts
    48
    2008 850D XUV here.
    I have none of the issues that the 3 of you have described. 4x4 is smooth. Reverse with diff lock on is smooth. Matter of fact I don't even know it's in 4x4 mode until I get unstuck.
    About 85 hours on unit and about 80 are trail riding.
    Is there something wrong that I am not feeling the tugs and rubs?
  6. #6
    New Member
    Join Date
    Jan 2008
    Posts
    21
    NE Pa
    John Deere 870 and Gator XUV
    I have the same problem on my 08. It will sometimes "bind" in forward or reverse. It seems like it is whenever both front wheels are engaged, and you stop while the wheels are still turned. It is easy to correct by just changing direction. You don't usually have to take it out of 4wheel drive, but on occassion it will stay locked in even if you switch directions, then you have to turn off the 4wheel drive. I also have had both front wheels stay engaged occasionally when I am using it hard in 4wheel drive. I notice it most when I am plowing snow and pushing it hard. You will get a low pitch hum and the steering is real hard. I have talked to several others and it happens at one time or another on a lot of them. Mine currently has about 150hrs on it and has done it from almost new.
  7. #7
    Gold Member shot_gun's Avatar
    Join Date
    Mar 2008
    Posts
    386
    NJ
    Just a thought but make sure you check your tire presure, 14 psi all the way around.
    S_G
    Remember nobody ever complained about having too much horsepower!
Similar Threads
  1. Price Check 2008 5203 4WD Price ans Compare
    By CWP37 in forum John Deere Buying/Pricing
    Last Post: 09-13-2007, 10:56 PM
  2. MF 1035 4wd problem
    By zilla24 in forum Massey Ferguson Owning/Operating
    Last Post: 05-21-2007, 12:25 PM
  3. XUV info I picked up
    By cef2lion in forum ATVs & Utility Vehicles
    Last Post: 01-26-2007, 09:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
