Results 1 to 4 of 4
  1. #1
    Gold Member
    Join Date
    Sep 2008
    Posts
    425
    Russell, PA
    BX24
    Default RTV900 oil pan heater
    I did my oil change today, and I installed a 50 watt oil pan heater while I was at it.
    I am very disappointed with the stock block heater for the RTV900 since it only heats the cylinder heads and does nothing for the rest of the water jacket. If it was lower on the block it would create circulation throughout the entire water jacket. oh well
    So, here are the photos of the oil pan heater going in. I like the patch-style heater since if fits nicely between the pan and the skid plate. I added some cable loom around the power cord where it runs under the skid plate mounting bracket as a chafe guard. I'm thinking that this should do the trick for at least a few winters.
    I'll plug both in about two hours before starting and that should take some of the stress off of the RTV.
    Attached Thumbnails Attached Thumbnails RTV900 oil pan heater-imag0321-jpg   RTV900 oil pan heater-imag0325-jpg
    Al Yelvington
    Russell, PA
    Kubota BX-24 & Kubota RTV-900
    FEL, BH, chipper, box grader, back blade, ford rake, disc harrow, sub-soiler, mid-soil buster, post hole digger, brush hog, spreader, sprayer, quick hitch, log splitter, block heater and lots of lights!
    www.youtube.com/ayelvington
  2. #2
    Member
    Join Date
    Jun 2007
    Posts
    30
    Maine
    Default Re: RTV900 oil pan heater
    How's that working? Thinking of trying it on a gator XUV diesel without a block heater. Burned out a radiator hose heater in a week
  3. #3
    Gold Member
    Join Date
    Sep 2008
    Posts
    425
    Russell, PA
    BX24
    I've only had to use it once so far, and it may have helped. My real reason for having it (and only 50W) was to keep the oil viscous enough to get flowing faster. My starts really depend on the battery charge and the glow plugs.
    I installed a battery charger (Harbor Freight) right on the battery compartment to keep that plugged in too...
    I must confess that I don't have troubles any more since I started using the RTV as a rolling wood pile. I fill it with wood and back it into our garage that I keep at 50F.
    So, I'd focus on the battery charge and all of the battery/glow plug connections for the easiest solution.
    Al Yelvington
    Russell, PA
  4. #4
    Silver Member lloyd123's Avatar
    Join Date
    Mar 2004
    Posts
    223
    Taxachusetts
    RTV900
    Here's a post I did back many years ago:
    http://www.tractorbynet.com/forums/a...er-rtv900.html
    I put a heater on the oil pan and transmission.
    My RTV900 is now almost eight years old. Still has original battery but I must use a trickle charger to keep it working on real cold starts. I only use for plowing so only have about 280 hours.
    The only real problem I've had is the "A" frame on the plow broke and it's about a $350 part to replace.
Similar Threads
  1. Liquid oil pan gasket
    By Nick359 in forum John Deere Owning/Operating
    Last Post: 02-20-2011, 12:53 AM
  2. Global Warming News
    By KB9UDE in forum Rural Living
    Last Post: 03-11-2010, 08:06 AM
  3. Waste oil heater for my garage.
    By dngspot in forum Build-It Yourself
    Last Post: 01-18-2010, 03:19 PM
  4. GM Oil Life Monitor
    By Doc_Bob in forum Oil, Fuel & Lubricants
    Last Post: 10-10-2009, 07:15 PM
  5. Hows this for new oil discussion
    By neucam in forum Oil, Fuel & Lubricants
    Last Post: 12-12-2008, 10:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
