Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    16
    Ontario, Canada
    Kubota/Rtv 900
    Default kubota rtv lift kit
    will the 2 inch lift on the rtv put a bad angle on the joints and damage the rtv and does the lift actually lift the back lower belly of the machine or just make room for bigger tires? Thanks alot, Dan
  2. #2
    Gold Member
    Join Date
    Mar 2010
    Posts
    392
    Canada
    RTV1100 2009
    Default Re: kubota rtv lift kit
    Just my opinion, yes.
    Joints are under lots of stress as it is and the extra angle would shorten their life.
  3. #3
    New Member
    Join Date
    Apr 2012
    Posts
    16
    Ontario, Canada
    Kubota/Rtv 900
    thanks spudhauler for the reply
  4. #4
    Gold Member cat 297c's Avatar
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Cat 299D XHP, Cat 297c, Rayco C140
    Default
    U will get a little more ground clearance with the lift but not much but throw on the lift and bigger tires u could gain upperwords of 4-5 inches in ground clearance.
    HFM LLC
    251-331-4475
    lifescapes-forestry-mulching.com
  5. #5
    New Member
    Join Date
    Apr 2012
    Posts
    16
    Ontario, Canada
    Kubota/Rtv 900
    i want to get the lift to but im afraid that the back lift will put the u-joints on a bad angle and they will get damaged or not last.
  6. #6
    Super Member timswi's Avatar
    Join Date
    Nov 2008
    Posts
    5,722
    Beaver County Pa
    Kubota BX23 TLB, Kubota RTV1100, Kubota Z724 & Polaris Sportsman 570 Touring
    Quote Originally Posted by rtvdan View Post
    I've seen a few guys here that had small lifts...I do somewhat remember them saying the same thing, but I don't recall any failures that were reported...Most lifts are 1.5"-2" so they aren't extreme...Or were you planning on going big time?
    BX23TLB with 54" MMM
    RTV1100 with 72" Power Angle Plow
    Z724 ZTR
  7. #7
    Elite Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    3,252
    texas
    Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
    My opinion would be get aggressive same size or one size larger if will fit and a good winch,that will mount on front or back. I have one thats welded to a reciever hitch but its a pain if your already stuck and need to dig down and get to the reciever hitch. Maybe titan 589's and Warn,Ramsey,Milemarker winch(4500lbs and up),tree saver and snatch block....kubota rtv lift kit-08-16-09_1553-jpgkubota rtv lift kit-stuck-prowler-jpg
  8. #8
    New Member
    Join Date
    Apr 2012
    Posts
    16
    Ontario, Canada
    Kubota/Rtv 900
    i was only planning on getting the 2 inch lift because the back end sits very low on the kubota. Im pretty sure you can only get 2 inch anyway.
  9. #9
    New Member
    Join Date
    Apr 2012
    Posts
    16
    Ontario, Canada
    Kubota/Rtv 900
    i already a 4500lb winch and i want to get 27" kenda executioner tires. ive heard from people on the internet that they will fit without rubbing. i like the tire because it last forever, it has great traction and its a very very strong, tough tire.
  10. #10
    New Member
    Join Date
    Apr 2017
    Posts
    24
    indianapolis indiana
    Deere, Kubota
    You absolutely CAN safely lift your RTV's 2 inches without premature wear...I will post details to clear-up what you can actually do to improve upon these machines, aging as the 900 and 1100 lines are.
Similar Threads
  1. Kubota lift arm question
    By Agrantina in forum Kubota Owning/Operating
    Last Post: 01-20-2011, 10:48 AM
  2. Insurance Kubota Pre-Cleaner Kit & GP
    By rScotty in forum Kubota Owning/Operating
    Last Post: 08-19-2010, 06:48 PM
  3. Kubota L245 3 point lift
    By estodd in forum Hydraulics
    Last Post: 09-25-2008, 08:15 PM
  4. Kubota B2782 snowblower subframe kit information
    By tamarack in forum Kubota Owning/Operating
    Last Post: 02-03-2008, 12:08 AM
  5. Operating Opportunity - Kubota vs Kioti
    By rtimgray in forum Owning/Operating
    Last Post: 12-28-2004, 04:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
