Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Member
    Join Date
    Mar 2012
    Posts
    30
    Bradenton FL
    2012 Kubota RTV900 (x4)
    Default Kubota RTV900 tire wear & camber
    Hey y'all--
    I'm experiencing uneven wear to the outside 1/3 of my front tires. You can see the positive camber (top of the tire is tilted out) and that's obviously the cause. I have the GP model with HDWS tires, hard top, glass windshield & wiper, soft doors, brush guard in front and hitch in rear. They run on 100% pavement. I tow with them, but the trailers are like farm wagons, with no tongue weight.
    I don't know if I have optional HD struts/springs. I'll check my invoice.
    Anyone have suggestions?
    thanks
    kevin
  2. #2
    Veteran Member smstonypoint's Avatar
    Join Date
    Oct 2009
    Posts
    2,266
    SC (Upstate) & NC (Piedmont)
    NH TN 55, Kubota RTV 900, Bad Boy Outlaw 61" ZTR
    Default Re: Kubota RTV900 tire wear & camber
    Kevin,
    My owner's manual is at my farm and so I can't check, but I thought there was a section on front-wheel alignment. Am I mistaken?
    Steve
  3. #3
    Join Date
    Jan 2012
    Posts
    139
    California
    Ford 7710, Ford 550, Ford 1910, Ford 4430, KD Forklift, Ford LGT17H, New Holland L255 Skidsteer
    Check your tow-in. Measure from tire to tire on the front of the tires at the center-line. Do the same at the rear of the front tire. Compare the measurements. They should be the same number, 0 toe-in OR toe-in of 1/4", the front being 1/4" narrow than the rear measurement.
  4. #4
    Member
    Join Date
    Mar 2012
    Posts
    30
    Bradenton FL
    Sorry for the waste of BW... I checked with the dealer, who says I do have HD struts (or springs, he couldn't recall which right away), which are specified with the cab package. He still has my standard parts and will give them back to me. I'll put them on and likely solve my problem.
    Steve-- Thanks for the reply. Only toe is adjustable. If changing the springs back to standard doesn't solve the problem, I may be able to modify the strut mounts for adjustable camber. We'll see...
    Thanks all
    kevin
  5. #5
    Member
    Join Date
    Mar 2012
    Posts
    30
    Bradenton FL
    TractorTech--
    Thanks, but a toe problem causes a different type of tire wear, and my incorrect camber is severe enough it's plain to see by eye - no measurement needed. If I get the front height down a bit, it should be fine.
    I can say the HDWS tires are obviously a lot tougher than the turf tires I was running on my previous vehicles. Who's got the best price on top-quality replacements?
    thanks
    kevin
  6. #6
    Member
    Join Date
    Mar 2012
    Posts
    30
    Bradenton FL
    Silverstone has OTR 350 HDWS for $95. That's the best I've found so far...
  7. #7
    Elite Member timswi's Avatar
    Join Date
    Nov 2008
    Posts
    4,340
    Beaver County Pa
    Kubota BX23 & RTV1100
    Quote Originally Posted by vfr700f2 View Post
    Thanks all
    kevin
    I had the same issue when my snow plow was removed..The HD struts do throw off the camber to compensate for the weight..Wish they were adjustable...With the OEM, normal struts, you should be fine...Running on 100% pavement is going to eat some tires regardless.
    BX23TLB & RTV1100 with 72" Power Angle Plow
  8. #8
    Veteran Member Ken45101's Avatar
    Join Date
    Feb 2009
    Posts
    2,473
    southern Ohio
    Kubota M5040, M9540, B21 TLB, B2710, RTV900, JD 325 Skid steer, KX-121-3 mini excavator
    Quote Originally Posted by timswi View Post
    I remember when we bought our RTV, the dealer said there were two options to beefing up the front end for the snow plow. Ours has been okay (500+ hours) so perhaps they went the other way (HD springs maybe? I don't remember.)
    Ken
  9. #9
    Platinum Member David_Kb7uns's Avatar
    Join Date
    Aug 2005
    Posts
    834
    Willamette Valley Oregon
    Kubota X 4
    thanks
    kevin
    Check with salesman at dealer. Tire and Rim combos through whole goods can be well priced, neighbor got bar tires for his BX cheaper than what his son could get them for working at a tire shop.
    David Kb7uns
    GL3130GST LA723 Loader, ATI grapple, ATI grapple bucket, WR Long front remote, Kubote rear remotes, Bradco 408 Backhoe with thumb, 60"KK brush hog, 60" RM Finish Mower, Speeco Post Auger, 72" KK rear blade, 60" box blade
    BX2230 LA211, RCK60, GCK60 Bagger,42"Land Pride Tiller, XB BB, XB RB, rake, Fimco 3PT sprayer
    G2160 RCK60 Mower
    RTV1100 Orange, Work Lights, Front Rear Winch,Rear Screen, High Mount air cleaner, water seperator
    2010 Polaris RZR 800 S
    2007 CAN AM Outlander 800 LTD
  10. #10
    Member
    Join Date
    Mar 2012
    Posts
    30
    Bradenton FL
    Thanks David. I'll check that out. Tires alone via Kubota parts are ~$140.
    I got my original springs back, so I'l get them on and see how it goes.
    Thanks all!
    kevin
Similar Threads
  1. Tires L-3130-HST right tire wear on outside. front axle problem.
    By tibzy in forum Kubota Owning/Operating
    Last Post: 04-16-2011, 07:33 PM
  2. L series tire question and problem.
    By AB4D in forum Kubota Owning/Operating
    Last Post: 12-19-2005, 06:46 PM
  3. Strange Tire Wear Pattern
    By dmccarty in forum Related Topics
    Last Post: 01-19-2005, 10:08 AM
  4. Operating Opportunity - Kubota vs Kioti
    By rtimgray in forum Owning/Operating
    Last Post: 12-28-2004, 04:20 PM
  5. Kubota RTV900
    By kenta in forum ATVs & Utility Vehicles
    Last Post: 12-19-2004, 12:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
