Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
  1. #11
    New Member
    Join Date
    Feb 2012
    Posts
    13
    Glendive, MT
    Kubota RTV 1100
    Default Re: Trailer or Car wheels for Kubota RTV 1100
    Quote Originally Posted by vfr700f2 View Post
    Hmmm... I've got RTV900s, and have fitted car wheels with 5x4.5 pattern on them. 5x114mm is about the same, and is probably the actual measurement, but then you have to search junkyards for oddball wheels. Maybe your 1140s have a different pattern.
    Anyway, I just tested the wheel fit today. The HD springs will be replaced with standard, the tires will go on and I'll be back on the road next week. Mine tow passenger tram trailers on pavement. I've had them about 3 months and put 800+ hours on each (I have 4), and the HDWS's are bald on the outside 2/3s of the tread, while the inside 1/3 is virgin. They've been rotated front to rear, but not dismounted and flipped inside to outside.
    I'm using Cragar Soft 8 wheels from Summit Racing, 15x7, 4" backspacing. They're about $55 ea. Tires will be 215/60/15. The wheel center bore is bigger than the kubota hub, so only the wheel bolts will hold them aligned. I'd like to stay hubcentric, but that'll be a research project for another day. The wheel bolt conical seats are just barely big enough to engage the conical holes in the wheel. I'm looking for a solution for that. A crutch for now is a flat washer, which will make itself cone-shaped when the wheel bolt is tightened.
    Will let you all know how the tires look in another 800 hours.
    later
    kevin
    Kevin I'm going to look into those wheels and as for the Bolt conical issue my dad designed a washer that would solve that problem for me. I'll take some pictures of them and pm them to you. Thanks everyone for the information.
  2. #12
    Super Member
    Join Date
    Jul 2009
    Posts
    9,011
    SW WA
    Kubota BX2360
    Quote Originally Posted by jpinkston70 View Post
    My front wheels are 25" while my back wheels are is 26". ... My front tires last maybe 3 months to 4 months.
    Front 25 x pi = 78.5 inches circumference
    Rear 26 x pi = 81.7 inches circumference
    Sounds like your front tires are skidding 3 inches with every revolution.
    Bruce
  3. #13
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,568
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Quote Originally Posted by bcp View Post
    You missed the part where he said that it is not in 4wd. As such, no skidding.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  4. #14
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,568
    If it is 5x108MM (4.25"), look for a Volvo... That is their bolt pattern. Anything RWD and pre-1996 (ie: 100, 200, 700 or 900 series) has a 25MM offset. Anything FWD made before 2001 (ie: 850, S70, V70) or RWD made between 1996 and 1998 (ie: 960, S90, V90) has the same bolt pattern and a ~43MM offset. Any of those Volvos will have a center bore of 65.1MM.
    See: Wheel Bolt Pattern Cross Reference Database and Conversion Guide: 5*X*108 for a good list of vehicles which take that pattern.
    If the spacing is 5x114.3MM (4.5") see: Wheel Bolt Pattern Cross Reference Database and Conversion Guide: 5*X*114.3 for a list of what you can get rims off of.
    Aaron Z
  5. #15
    Super Member
    Join Date
    Jul 2009
    Posts
    9,011
    SW WA
    Kubota BX2360
    Quote Originally Posted by aczlan View Post
    Aaron Z
    Yep. Reading too fast. Thought he was in 4wd.
    Bruce
    PS-Could it have a malfunction so it is in 4wd even though the control is in 2wd?
  6. #16
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,568
    No harm done...
    Could be. Probably not though as with that much difference in tire sizes you would notice it.
    Aaron Z
  7. #17
    Member
    Join Date
    Mar 2012
    Posts
    33
    Bradenton FL
    2012 Kubota RTV900 (x4)
    In these pics the HD front springs were still installed. In the 2nd pic you can see how my original tires were wearing.
    Trailer or Car wheels for Kubota RTV 1100-2012080614_28_58-vi-jpg
    Trailer or Car wheels for Kubota RTV 1100-2012080614_29_06-vi-jpg
    Trailer or Car wheels for Kubota RTV 1100-2012080614_29_23-vi-jpg
    Trailer or Car wheels for Kubota RTV 1100-2012080614_28_48-vi-jpg
    Four 2012 RTV900s, towing 2000LB-5000LB, 12 hours per day, every day, on pavement.
  8. #18
    Member
    Join Date
    Mar 2012
    Posts
    33
    Bradenton FL
    Aaron Z
    Which is too small for a kubota, according to the measurements on the previous page. Just sayin'
  9. #19
    Elite Member milkman's Avatar
    Join Date
    Sep 2001
    Posts
    3,553
    Ky. Between Dead Horse Holler and Yellowbank
    BX2200, BCS 735
    I still have the same question, have you checked your toe-in, if it's toed in it will scrub the outside of the tires off also. I can see that the tires are out at the top, but toe-in will make it wear a lot sooner.
    Hate is like drinking poison, hoping your enemy will die. unknown author
  10. #20
    Member
    Join Date
    Mar 2012
    Posts
    33
    Bradenton FL
    Milkman--
    Do you see bad camber on the camo RTV or the blue one? The blue one is mine, and it definitely has (had) a camber problem. The camo one belongs to the OP (jpinkston70) and I can't see a camber problem in his pic.
    So I agree he needs to check his toe. He should be able to get several thousand miles out of HDWS tires (though he has ATV tires now) on pavement with good alignment. With my bad camber, I still got 900 hours (~2500+ mi) on pavement before I went thru the cords.
    kevin
Similar Threads
  1. Buying Advice Kubota RTV 1100
    By angussprings in forum Kubota Buying/Pricing
    Last Post: 11-03-2011, 02:04 PM
  2. Kubota rtv 1100
    By kubota1986 in forum Customization
    Last Post: 09-05-2011, 07:38 PM
  3. Kubota rtv 1100
    By oneal in forum Kubota Owning/Operating
    Last Post: 05-02-2011, 04:35 PM
  4. Price Check Kubota RTV 1100
    By allen13331 in forum Buying/Pricing/Comparisons
    Last Post: 11-24-2010, 07:18 PM
  5. Substituting car wheels for trailer wheels? Offset issue?
    By KYErik in forum Trailers & Transportation
    Last Post: 01-11-2008, 01:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
