Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
  1. #21
    Elite Member milkman's Avatar
    Join Date
    Sep 2001
    Posts
    3,550
    Ky. Between Dead Horse Holler and Yellowbank
    BX2200, BCS 735
    Default Re: Trailer or Car wheels for Kubota RTV 1100
    Quote Originally Posted by vfr700f2 View Post
    Milkman--
    Do you see bad camber on the camo RTV or the blue one? The blue one is mine, and it definitely has (had) a camber problem. The camo one belongs to the OP (jpinkston70) and I can't see a camber problem in his pic.
    So I agree he needs to check his toe. He should be able to get several thousand miles out of HDWS tires (though he has ATV tires now) on pavement with good alignment. With my bad camber, I still got 900 hours (~2500+ mi) on pavement before I went thru the cords.
    kevin
    I can see the positive camber in your second photo, is that before or after the fix? It's hard to tell from photos, so if taken from floor level, they would probably look different. The old VWs had a lot of camber in the rear wheels and they still got a lot of miles on the tires.
    Hate is like drinking poison, hoping your enemy will die. unknown author
  2. #22
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,545
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Which is too small for a kubota, according to the measurements on the previous page. Just sayin'
    Ah, I missed that there was a center size listed.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  3. #23
    Member
    Join Date
    Mar 2012
    Posts
    33
    Bradenton FL
    2012 Kubota RTV900 (x4)
    My photo is from before changing springs. Camber was definitely way out. With stock springs they're fine and tire wear is normal.
    That said, running lots of miles on pavement, HDWS tires wear out an an uneconomical rate. That's why I'm changing to car tires.
    The lug bolt issue definitely must be addressed. I'm not running them until I get something that will seat properly in the bolt hole in the wheel.
    kevin
    Four 2012 RTV900s, towing 2000LB-5000LB, 12 hours per day, every day, on pavement.
  4. #24
    Member
    Join Date
    Mar 2012
    Posts
    33
    Bradenton FL
    I checked all the usual industrial suply houses (McMaster, Fastenall, Grainger, etc) and a mess of auto part and hardware suppliers but could not find 7/16-20 double-ended studs so I can convert to wheel studs and nuts. That's what I really wanted. Couldn't find wheel bolts in 7/16-20. Talked to my machinist about making conical spacers to use on a plain bolt, and he said making studs would be easier for him and would give me what I want. So that's what we're gonna do. Then I can use regular lug nuts.
  5. #25
    Join Date
    Jul 2012
    Posts
    168
    Summit Racing (summitracing.com) has them. Not sure if they are the right length for your application, though.
    In the past, I have converted to studs by threading bolts through from the back side of the hub. Again, I don't know if that will work for your application.
    If all else fails, 7/16-20 is available in threaded rod.
  6. #26
    Member
    Join Date
    Mar 2012
    Posts
    33
    Bradenton FL
    Summit was one of the first places I looked, and I just looked again. If they have a 7/16-20 wheel bolt, please post the link.
    I didn't think about threading bolts in from the back. I'll check that out.
    thanks!
    kevin
  7. #27
    Join Date
    Jul 2012
    Posts
    168
    thanks!
    kevin
    My mistake, They don't have 7/16-20 in wheel bolts. I thought they did.
    Sorry about that.
    Misfire
  8. #28
    New Member
    Join Date
    Aug 2012
    Posts
    1
    Rock Stream,NY
    Ford 641 workmaster,RTV900
    vfr700f2,
    Try a search on ebay for item # 290385803292. Might be what your looking for.
    artvan
  9. #29
    Member
    Join Date
    Mar 2012
    Posts
    33
    Bradenton FL
    Hi Artvan! Don't know how I didn't see your reply. Those look like the same bolts I got, but by the time my kubota dealer found them, bought them and sold them to me, I paid a lot more than that. Though an RTV900 needs 20 bolts and that auction is for 16.
    Anyway, I did get bolts and got the wheels/tires on the first of my RTVs. My bolts came from Essex Mfg, Essex Contact Page but they're not on the webpage. Essex sells wheel conversion packages of their own, with wheels and tires (and bolts, I assume).
    My wheels/tires/bolts fit great. As I think I mentioned above, 15x7 wheels with 3" backspace seemed likely to stick out too far. I switched to 4" backspace and they work fine. Possibly 3.5" backspace would be great but there aren't as many wheels to choose from in that size.
    My HDWS tires lasted about 800 hours on pavement. I'll let y'all know how my new Sumitomo HTR4s look in 3 months when I have 800 hours on those. I hope to see 2400+ hours of total life from them.
    later
    kevin
  10. #30
    New Member
    Join Date
    Feb 2012
    Posts
    13
    Glendive, MT
    Kubota RTV 1100
    Alright I finally have an update. I went and bought those rims that you have Kevin, except I went with a 15x8 ( http://www.summitracing.com/parts/SUM-85-5865/ ) with a 3.75 inch backspacing giving me a little wider footprint. I went with a Falken ZIEX ZE-912 215/60/R15 tire. I have to say it rides much smoother now. There's no scrubbing when I turn either. My rear driver side tire wobbles and I believe it is from when I was playing on ice and ran into a creek bank. So that will be my next fix. Found out someone makes a hub centric (correct my spelling) thing, I haven't looked for any yet but summit racing might have them. I'm going to install the studs and lug nuts today. Thank ya'll for all the feedback.
    Trailer or Car wheels for Kubota RTV 1100-img_20120822_185338-jpg
Similar Threads
  1. Buying Advice Kubota RTV 1100
    By angussprings in forum Kubota Buying/Pricing
    Last Post: 11-03-2011, 02:04 PM
  2. Kubota rtv 1100
    By kubota1986 in forum Customization
    Last Post: 09-05-2011, 07:38 PM
  3. Kubota rtv 1100
    By oneal in forum Kubota Owning/Operating
    Last Post: 05-02-2011, 04:35 PM
  4. Price Check Kubota RTV 1100
    By allen13331 in forum Buying/Pricing/Comparisons
    Last Post: 11-24-2010, 07:18 PM
  5. Substituting car wheels for trailer wheels? Offset issue?
    By KYErik in forum Trailers & Transportation
    Last Post: 01-11-2008, 01:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
