Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    1
    Ste. Genevieve, MO
    '09 Gator 620i
    Default '09 Gator 620i popping/clunking noise in front end
    I bought an "09 Gator 620i a year ago with 73 hrs on it. It has developed an annoying popping/clunking sound in the front end. It makes the noise on any surface, at any speed, in 2 wd, 4wd and neutral. Prior posts on this site note that a backlash adjustment screw may need to be turned counterclockwise an 1/8 to 1/4 turn to help reduce this condition. Has anyone else been experiencing this problem recently and did adjusting the screw help? Further, where is the allen head screw located?
  2. #2
    Veteran Member jimgerken's Avatar
    Join Date
    Nov 2001
    Posts
    1,638
    Minnesota
    John Deere 3720
    Default Re: '09 Gator 620i popping/clunking noise in front end
    Sounds like a bad CV joint to me.
Similar Threads
  1. B7500 front end noise
    By Theridge in forum Kubota Owning/Operating
    Last Post: 09-28-2012, 10:47 AM
  2. 4200 jd front end noise
    By boydpettitt in forum John Deere Owning/Operating
    Last Post: 07-02-2012, 03:34 PM
  3. 4110 Mahindra popping noise in front end
    By BillBeyer in forum Mahindra Owning/Operating
    Last Post: 05-25-2010, 03:29 PM
  4. M105X front end noise
    By stuckinmud in forum Kubota Owning/Operating
    Last Post: 04-14-2010, 07:04 PM
  5. 2544 axle popping noise rear end
    By evan4434 in forum Cub Cadet Tractors
    Last Post: 08-09-2008, 11:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
