Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
  1. #11
    Gold Member
    Join Date
    Mar 2010
    Posts
    392
    Canada
    RTV1100 2009
    Default Re: RTV 1140 Rear drive issue
    Yes and that would be normal Tim as the splines wore the hub would be able to move inward leaving it loose. The nut was probably never actually loose, it was the wear that made it loose. Too bad more people didn't get the notice on this new torque spec. The fix will be expensive.
  2. #12
    Super Member smstonypoint's Avatar
    Join Date
    Oct 2009
    Posts
    7,199
    SC (Upstate) & NC (Piedmont)
    NH TN 55, Kubota B2320 & RTV 900, Bad Boy Outlaw ZTR
    Quote Originally Posted by SpudHauler View Post
    I'm with you Timm250. That is most likely what happened here. I was close but forgot about the spline issue.
    Good call.
    Tightening torque was 110 ft/lbs on that big slotted nut and that was upgraded to 140 ft/lbs. As far as I know that is only on the rears.
    I'm going to check this on my RTV 900 when I get back to the farm next week. I don't have that many large metric sockets. Any idea about the size of the nut?
    Steve
  3. #13
    Gold Member
    Join Date
    Mar 2010
    Posts
    392
    Canada
    RTV1100 2009
    I knew that question was asked before but forgot it was I that answered it. North of 60, memory good but short.
    17mm nut.
    http://www.tractorbynet.com/forums/a...ml#post2389300
  4. #14
    Join Date
    Oct 2009
    Posts
    7,199
    17mm nut.
    Thanks.
    I'm confused, which is nothing out of the ordinary.
    Reference was made to a large slotted nut in an earlier post. I was under the impression that the nut was under the plastic cap that covers the end of the hub. Am I off base?
    Steve
  5. #15
    Super Member texasjohn's Avatar
    Join Date
    Oct 2005
    Posts
    6,048
    Central Texas, Jarrell
    Kubota Grand L5030HSTC
    yep, me too confused----don't know exactly what nut has new torque specs...I'd like to check mine but not sure where it is...can Somebody do a photo or description?
    Joy is having the tools you need and needing the tools you have!
    Kubota 5030 HSTC, BB, Danueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall, Kubota RTV 1140
  6. #16
    Gold Member
    Join Date
    Mar 2010
    Posts
    392
    Canada
    RTV1100 2009
    Yes you are right, it is under the rubber cap and is slotted for the cotter pin that secures it. Manual calls it the "slotted nut".
    This manual listed the 110 ft lbs of torque and the update is to go as high as 140 ft lbs.
    Just shows how much extra strength is available in these nuts and bolts, huge safety factor.
    Like this:
    Attached Thumbnails Attached Thumbnails RTV 1140 Rear drive issue-rtv1100-rear-axle-jpg
  7. #17
    Join Date
    Oct 2009
    Posts
    7,199
    Spudhauler,
    Thanks for the clarification. Is the slotted nut also 17mm?
    Steve
  8. #18
    Gold Member
    Join Date
    Mar 2010
    Posts
    392
    Canada
    RTV1100 2009
    Oh! You were thinking the 5 wheel nuts were what was being referred to here.
    The wheel nuts are 14 mm (55-66 ft lbs torque) I routinely went 60 ft lbs for these.
    The axle nut is 17 mm (was 110 now 150 ft lbs torque)
  9. #19
    Join Date
    Oct 2009
    Posts
    7,199
    Thanks again. I have a 17mm socket, so I'm good to go.
    Steve
  10. #20
    Join Date
    Oct 2005
    Posts
    6,048
    thanks for this image..got it..checked WSM for my 1140 and it does show 140 fp torque, then tighter if needed to align cotter pin...just gotta get me a wrench that reads into these big numbers...
Similar Threads
  1. Kubota RTV 1140
    By deerman2160 in forum Kubota Owning/Operating
    Last Post: 09-06-2014, 07:18 PM
  2. RTV 1140 Using Coolant
    By JB00 in forum Kubota Owning/Operating
    Last Post: 01-02-2013, 03:07 AM
  3. anyone here have the rtv 1140 cpx?
    By FamilyFarm in forum ATVs & Utility Vehicles
    Last Post: 09-03-2012, 07:37 AM
  4. rtv 1140
    By kunota man in forum ATVs & Utility Vehicles
    Last Post: 03-07-2011, 08:43 AM
  5. rtv 1140
    By bigdeer2000 in forum ATVs & Utility Vehicles
    Last Post: 09-24-2008, 06:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
