Results 1 to 2 of 2
  1. #1
    Join Date
    Oct 2007
    Posts
    249
    Esperance NY
    JD 4103
    Default 4010 Trans mule 2009 gas crew cab service for 325 hours
    Hi Guys
    I am servicing my mule 2009 gas mule trans 4010 335 hours. I know what
    filter for oil fram #4967
    1.3 or 1.4 oil I believe it is 10W to 40W
    Change air filter
    Grease the one fitting
    replacing the spark plugs
    question 1) My question is there transmission fluid I know my gator did, but this go off engine oil?
    question 2) What else should be looked at and adjusted?
    question 3) As it has power steering does it have power steering fluid?
    question 4) Cooling fluid how can you check?
    As much of these things cost I am doing everything I can to take care of it. I use mine almost
    everyday and could run game preserve without it. Does anybody know if manuals are online
    anyplace. I am too cheap to buy it and can find the one I got with the machine.
    Michelle Linnane
    Stonewall Boarding and Game Preserve
    www.stonewallboarding.com
  2. #2
    Gold Member Happyman's Avatar
    Join Date
    Jun 2008
    Posts
    478
    Kents Store, Virginia
    Kubota Grand L 3940
    Default Re: 4010 Trans mule 2009 gas crew cab service for 325 hours
    Quote Originally Posted by Michelle K linnane View Post
    Hi Guys
    Change air filter
    Yes, there is transmission oil that needs to be changed at some point. Same goes for gear oil in the front differential.
    There is no fluid for the power steering. It's electric.
    Cooling fluid is usually checked by looking at the reservoir bottle under the front hood. You can drain the old fluid from a drain cock under the radiator. Just remember to take the radiator cap off first so it will drain faster. Wait until it cools down!
    I found the service manual for my 2007 gas trans on-line for $7.00. Downloaded as a pdf then printed it.
    Really not any other adjustments to make unless your parking brake isn't holding or the drive belt is slipping.
    Good luck!
    Grand L3940 HST, Wallenstein BX62 chipper, Woods GTR72 tiller, Woods BH90-X backhoe, 724 FEL, forks, 1000lb PTO rotary spreader, Woods PRD8400 finish mower, Leinbach 7' landscape rake, United 7' box blade, Pequea 80 bushel manure spreader, Woods 7' Brush Hog.
Similar Threads
  1. 4010 trans mule gas speed/odometer solved
    By murphyboy in forum ATVs & Utility Vehicles
    Last Post: 06-05-2011, 05:46 PM
  2. 2009 gas 4010 mule oil filter
    By Michelle K linnane in forum ATVs & Utility Vehicles
    Last Post: 04-04-2011, 08:28 AM
  3. Mule 4010 Trans roof?
    By zene55 in forum ATVs & Utility Vehicles
    Last Post: 01-06-2011, 09:42 PM
  4. 2009 trans 4 x4 mule got it tuesday
    Last Post: 12-13-2009, 08:43 PM
  5. 4010 Diesel Trans Mule Power Dump?
    By 454shooter in forum ATVs & Utility Vehicles
    Last Post: 03-22-2009, 09:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
