wawajake
I did the 50 Hr maintenance on my new Kubota RTV X1100C this weekend, it included such things as engine oil and filter change , and both transmission filters and of course the many many many grease points to do. I was disappointed on Kubota's lack of thinking when it came to access to the filters for example. The engine oil filter is buried and after you remove the large engine protection plate , the filter is still buried behind cables and tight against a rad hose. Also even though it looked like it would be a breeze to change the transmission filters at back of engine just sitting on a stool .......except that the space only allows your wrench to turn barely a half inch at a time. I did like that you only lose less than a litre of UDT fluid doing those two. It was nice to learn the machine, although the operator guide is vague on some of the grease locations . How did everyone else find their first maintenance on their Kubota side by side ?
