Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Apr 2010
    Posts
    2
    ohio
    2000 Exmark Lazer Z Fuel injected Spec #PS78511
    Default 12 pin to 6 pin attachment connector
    I have a 763H & I purchased a Bobcat stump grinder. My 763H has a 14 pin attachment connector & the late model stump grinder has a 7 pin connector. Does anyone make a harrness to convert the 14 to 7 pin connector?
  2. #2
    Member
    Join Date
    Sep 2004
    Posts
    40
    Florida / MD
    Kubota ZD331 Toolcat 5600
    Default Re: 12 pin to 6 pin attachment connector
    I have the small plug on my Toolcat and a large plug on an attachment. I was told yesterday by Bobcat that I would have to change the wiring on the Toolcat. I think somone is wrong and there must be a way to change back from the large to the small.
  3. #3
    New Member
    Join Date
    May 2009
    Posts
    5
    I'm not 100% sure but I think the 6 pin and the 12 pin are not compatible so a conversion does not work. I believe you need to get the other harness. Which kinda sucks cause they are not cheap.
  4. #4
    Gold Member
    Join Date
    Sep 2003
    Posts
    365
    Central Idaho Mtns
    Kubota BX-23 & Toolcat 5600 D
    Check out the Toolcat forum. I suggest going there and searching on this topic as it has been flogged repeatedly.
Similar Threads
  1. 12 pin to 6 pin attachment connector
    By overseas in forum Bobcat Construction Equipment
    Last Post: 02-18-2011, 03:02 AM
  2. Connect PTO shaft using pin or bolt?
    By Richard in forum Parts/Repairs
    Last Post: 11-23-2008, 09:27 AM
  3. 3ph pin broken
    By wayupnth in forum John Deere Owning/Operating
    Last Post: 11-09-2008, 10:24 PM
  4. Help us design on our Mulcher Attachment
    By bubenberg in forum Attachments
    Last Post: 01-25-2005, 08:53 PM
  5. Virus
    By Bird in forum Related Topics
    Last Post: 09-20-2001, 09:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
