I have a 2002 s185 turbo bobcat it will not start using the start button. Gives codes 13-07 and 18-06. HAVE REPLACED BATTERY, CLEANED CONNECTIONS If you tie the fuel solenoid in and cross starter over with screwdriver it will start and run fine. Worked fine last time used, was not used for approximately 2weeks then when tried to start thats when wouldent.
