Results 1 to 8 of 8
  1. #1
    Elite Member AlanB's Avatar
    Join Date
    Jan 2004
    Posts
    2,532
    Clarksville, TN, USA
    NH 1925
    Default 743 Massive hydro leak
    Hi, I have an older 743 and have a massive hydro leak that as peculiar as it sounds I am having trouble narrowing down exactly where it is coming from. I originally thought I had blown the hydro cooler, but after pulling the panels and running it, the oil is down lower and it was blowing up through with the fan. My best guess is that it is at the very back / aft / engine end of the hydro assembly, or one of those lines there, I am just having a real hard time seeing anything forward of the engine other than the oil pouring out the bottom. I have the cab rocked open now, and was going to hotwire it and start it with the cab up next, but even now, I am having a hard time seeing the back of that hydro unit. Anyone have suggestions on what / where to look. Hate to pull the engine and not know exactly what I want to change, hard to troubleshoot if I cannot make it leak. Thanks for any help. Alan Bechard
  2. #2
    Veteran Member RPW's Avatar
    Join Date
    Aug 2009
    Posts
    1,037
    Default Re: 743 Massive hydro leak
    First power wash so you can see easier. I believe the 743 is diesel so disable the fuel pump (and or use shutoff valve if iquiped) so the machine won't start when cranked. Place machine on jack stands according to manual. With a remote starter and possible flashlight crank while observing hydraulic compartment. By cranking without starting you'll minimise the safety risk of high pressure hydraulic fluid hitting the skin. Also the "pouring out" will be minimised and you won't have quite the mess.
    Hope this helps.
    2008 JD 5103, FEL, 6' Frontier, 6' HD boxblade, 7' Landscape rake, More impliments to come, Bobcat (clark) 742 SS.
  3. #3
    Join Date
    Jan 2002
    Posts
    168
    Cleveland GA
    varies never keep one long enough to post here lol
    If you havent got it fixed yet, its gonna be the steel pipes running behind the engine. Replace them with regular hydraulic hoses ran under the engine.
  4. #4
    Join Date
    Jan 2004
    Posts
    2,532
    NH 1925
    Thanks all, I have not got my act together and had time to get back on it yet. (need too) spent the morning so far under the dingo and on the phone looking for tracks for it.....
    Man, are they proud of those darn things.
  5. #5
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    You might try that leak detecting fluid that you put in oil or hyd fluid. After the leak detecting fluid is circulated in the system, take a black light and shine it every where you can. The leak will show up as a yellow or green glow due to the fact that it fluoresces under a black light.
    http://www.spectroline.com/pdf/OPK-340_Flyer.pdf
    UView Multi-Purpose Oil/Gas UV Dye - 6 Pack : ShoppersChoice.com
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  6. #6
    Join Date
    Jan 2004
    Posts
    2,532
    NH 1925
    Quote Originally Posted by gatractorman View Post
    Had to look at the dates to see how long it had been broke, so I am not the fastest
    GAtractorman hit the nail on the head but I did replace with original again. $100 for the factory lines.
    Pulled the engine a couple weeks ago, ordered lines, had them the same week, then put the engine back in and got it going again the next weekend I think it was.
    Now I remember the other little things I need to sort around on the dang thing
    It is good to have it running again.
    Thanks gatractorman for telling me where the problem was, I really hated pulling that engine without having first found the leak your post gave me the confidence that it would be there.
  7. #7
    New Member
    Join Date
    Nov 2011
    Posts
    3
    Boncat 743
    I have the same problem..... I pulled the engine and see about 10 hard line in there.... which one(s) are the normal problem?
  8. #8
    New Member
    Join Date
    Nov 2011
    Posts
    3
    Boncat 743
    Default
    I really need to know which line(s) to replace....... I'm down till I get some advise........Please help
Similar Threads
  1. KUBOTA BX2230 HYDRO LEAK
    By redneckarchery.com in forum Hydraulics
    Last Post: 09-29-2009, 05:45 PM
  2. Hydro leak...TC24DA
    By TCBoomer in forum New Holland Owning/Operating
    Last Post: 12-08-2005, 04:30 PM
  3. 4120 (not hydro) has a leak?
    By tillboy2001 in forum John Deere Owning/Operating
    Last Post: 04-10-2005, 12:30 PM
  4. 4120 (not hydro) has a leak?
    By tillboy2001 in forum New Holland Owning/Operating
    Last Post: 04-03-2005, 07:16 PM
  5. Lost plug - leaking hydro oil
    By nh1520 in forum Parts/Repairs
    Last Post: 05-30-2004, 12:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
