melroe bobcat 753g "input" error message?
   / melroe bobcat 753g "input" error message? #1
TRITECH
753g ingersoll rand bobcat
i have a 753g bobcat thet comes up with an "input" message when i turn on the ignition key.i have checked all fuses and relays.disconnected the battery and then reconnected it.replaced the top left console.still no go!any ideas?
regards;tritech
   / melroe bobcat 753g "input" error message? #2
regards;tritech
Check the controller inside the left fender, check for mice chewing wires in that area to, also unplug the j1 and j2 connecters on controller and lube pins with dielectric grease
GDAY BOBCATMAN;I DON'T HAVE A CONTROLLER UNDER THE FRONT FENDER (MY BOCAT IS A MELROE 753G UNIT), THERE IS A MAIN CONTROLLER UNDER THE SEAT WHEN YOU LIFT IT.
IT IS BLACK AND ABOUT 14 INCHES LONG, 8 INCHES HIGH AND 2 INCHES WIDE.
I WILL TRY TO UNPLUG AND RE-SEAT THE SOCKETS ON IT.
I HAVE CHECKED FOR MICE AND NO SIGNS OF CABLES BEING CHEWED.
TRIED THE CODES THING WITH THE LIGHT BUTTON BUT STILL COMES UP WITH "inPut"??
ANY MORE SUGGESTIONS?
REGARDS;TRITECH
BOBCATMAN; NO LUCK WITH ANY PLUGS ETC ON THE MAIN CONTROLLER.
ANY MORE IDEAS???
STILL GETTING THE "INPUT" MESSAGE.
REGARDS;TRITECH
   / melroe bobcat 753g "input" error message? #5
ANY MORE IDEAS???
REGARDS;TRITECH
I have the same input code pop up on my bobcat 753. Did you ever find the problem?
   / melroe bobcat 753g "input" error message? #6
Low battery voltage can cause the "input" error to display.
